How do you set the intensity of the rest interval
basilic
by basilic
I was told that for one minute on, one minute off intervals, if you do the "high intensity" period at X watts, the rest period should be at half X, or slighhtly higher. No justification was offered.
Recently I did the rest much lower (at X/3), by mistake, and discovered that I felt fresh as a daisy, could do more intervals than the usual 10, and/or at a higher wattage. So what gives? what is the benefit of a more intense rest period, if that prevents you from doing more or more intense HIIs? What is the downside of lower intensity rest periods?
I don't care all that much about the results, but I'd like to understand the physiology.
Any insight appreciated!
AJS914
by AJS914
It depends on the goal of the workout.
You could do 30 second all out sprints with 5 minute recovery to build anaerobic capacity. The long recovery allows you go maximal each time.
Or you could do 30 seconds hard / 15 seconds easy as a Billat style VO2max interval. The 15 second rests allow you to do more work than a continuous interval while keeping the HR will elevated for longer.
I always liked this podcast:
https://www.fasttalklabs.com/fast-talk/ ... ian-weber/
daneferrari
by daneferrari
AJS914 wrote:
Thu Apr 13, 2023 3:37 pm
Hi, I am a beginner and would like to ask this question: should I allocate a certain amount of time per day to training so that my body gets used to it? Or can the hours vary from day to day?
Best regards
