Custom XT mech direct mount
motorapido
by motorapido
Looking at neatening up the mech hanger on my Niner BSB RDO, i use an XT Di2 rear mech and find that the Llindaretts 11 adaptor improves the shifts with the cassette i run.
Only tried out an RP part for for this so far buton the stand the shift is good. Since its from a 3D model i'm currently exploring a few options for the final part. Options are RP sintered Ti alloy, RP sintered Al alloy, Machined from 6061T6 aluminium. Or if its its good enough for magura brakes a CF reinforced RP Nylon, MarkForged Onyx with constant strand CF reinforcement is almost as strong and stiff as Aluminium and the sections are thicker than most aftermarket Aluminium machined offerings. Calcs indicate it should be fine and piece parts price is good.
Although the frame is quick release i use a through axle, a 135x10 RWS axle which has a 20mm diameter locknut that makes the mech hanger interface really strong and rigid.
ImageIMG_20240611_182707_edit_394163452161727_resized_20240616_074722125 by Paul Townsend, on Flickr
ImageIMG_20240611_190145_resized_20240616_070713851 by Paul Townsend, on Flickr
ImageIMG_20240611_184840_resized_20240616_070713149 by Paul Townsend, on Flickr
ImageIMG_20240611_184813_resized_20240616_070714106 by Paul Townsend, on Flickr
ImageIMG_20240611_184741_resized_20240616_070713555 by Paul Townsend, on Flickr
