Lachlan Morton’s tyres for Unbound
cunn1n9
by cunn1n9
Looks like Lachlan Morton ran 2.1” Vittoria Mezcal tyres on his Cannondale Supersix Evo SE. However according to Cannondale the max tyre size is 45mm. 2.1” is nearly 54mm which is nearly 10mm larger than what Cannondale says.
So has anyone got this bike and can comment on the tyre tolerance?
Also I am interested in running tyres this size and was wondering the list of gravel frames on which it might fit so keen to know anyone that has tried an XC MTB tyre in a gravel bike successfully and what the frame was.
kervelo
by kervelo
The front tyre seems to be a Terreno Dry 54 x 622 (2.1). The rear tyre is a Mezcal, but the size is hard to see; it looks narrower than the front. If you zoom in the image at cyclingnews you may be able to see the size.
https://www.cyclingnews.com/features/ne ... h-gallery/
warthog101
by warthog101
What is going on with that saddle position?
No saddle 5cm behind the bb rule in gravel?
If you line the bb up with those brick lines, the saddle nose is not far behind it.
Edit. The rules look pretty relaxed.
https://www.unboundgravel.com/officialrules/
CarlosFerreiro
by CarlosFerreiro
BikeRadar say "Up front, he ran a 50mm-wide Terreno Dry, which didn’t leave much room for mud in the fork. Out back was a 44mm-wide Mezcal."
https://www.bikeradar.com/features/tech ... vel-trends
kervelo
by kervelo
CarlosFerreiro wrote:
Wed Jun 05, 2024 2:13 pm
BikeRadar say "Up front, he ran a 50mm-wide Terreno Dry...
I think BikeRadar has a typo in their text. The front tyre markings are quite visible in the image if you zoom in.
https://cdn.mos.cms.futurecdn.net/y7BNx ... 560-80.jpg
Volsung
by Volsung
warthog101 wrote:
Wed Jun 05, 2024 1:35 pm
he did a brief interview with Gravel Cyclist and said it's due to back pain
warthog101
by warthog101
Volsung wrote:
Thu Jun 06, 2024 2:43 pm
MasterBean
by MasterBean
Am I correct that those wheels are only 21mm wide?
Sent from my COL-L29 using Tapatalk
jfranci3
by jfranci3
Front tire is clearly marked 54 2.1 x 29. Looks like a Terreno Dry XC MTB
Rear clearly says Mezcal. They have a 44 and a 54. EF Instagram comments says 44c
ceriks
by ceriks
MasterBean wrote:
Thu Jun 06, 2024 4:21 pm
Yes, I've got the 60s of this wheel. The internal width is 21
CampagYOLO
by CampagYOLO
It's definitely a 44mm Mezcal at the back.
By the way I'm currently running 44mm Mezcals front and rear and really impressed with them, possibly my favourite gravel tyre. Very versatile until things get too muddy.
