Sram Wide Crankset and Quarq Compatability
commendatore
by commendatore
Saw a few versions of this question but no definitive answer. I have a cervelo aspero (aquired second hand) built up with a Sram Force AXS Wide front derailleur and Wide 43/30 crankset. As I understand it, the "wide" is all in the spindle (and needs a matching wide front derailleur). With that in mind, I should be able to swap the chainrings for an axs 46/33 power meter (and keep the wide crank arms).
Sram officially says "no" but I don't understand why. If I can save the expense of buying a full crank AND a regular front derailleur that would be ideal.
Jcamp
by Jcamp
On my Aspero I’m running D2 force wide up front, with 48/35 quarq integrated chainrings so you shouldn’t have any issue.
dzl
by dzl
I am running SRAM Force AXS Wide crankset with the Axs powermeter spider and 46/33 rings with no issues.
