2024 Shimano RX825 2x12 GRX Di2
otnemem
by otnemem
Any lighter cassette options for 12-speed 11-36?Maybe Garbaruk will work on one?
Rotor's cassette doesn't work great, does it?
LainOTN
by LainOTN
I'm wondering,
We have an existing 1x12 speed 10-51 di2 SD300 wide range rear derailleur, the M-8150-12 Deore XT.
https://bike.shimano.com/en-US/product/ ... 50-12.html
Does anyone tried to hook this up to a SD300 (12 speed) system? for sure is not wireless, but it might work just as good wired on a 1x12 GRX/Ultegra/DA setup.
TerryDi2C
by TerryDi2C
That derailleur is not a junction A, and it doesn't have a charge port either :)
(and according to Shimano's Di2 compatibility info, it's not compatible)
LainOTN
by LainOTN
TerryDi2C wrote:
Wed Jun 05, 2024 9:30 am
Acording to shimano info ST-RX825 are wireless only and I have them wired on my system :)
You are right about the charge port but as a hack will be interesting to know if it works, even if charging the battery will be challanging in this situation.
TerryDi2C
by TerryDi2C
hah, that's interesting! That must be a mistake in the documentation! :)
(I'll ask Shimano)
I suspect someone copied the 105 docs/specs and forgot to update that...
TerryDi2C
by TerryDi2C
LainOTN wrote:
Wed Jun 05, 2024 10:44 am
I asked, and yeah.. it's a mistake in the docs - it's being corrected soon :). Well spotted!
LainOTN
by LainOTN
TerryDi2C wrote:
Thu Jun 06, 2024 7:48 pm
Thanks, :)
Ask them also to update the compatilibity chart for Di2.
https://bike.shimano.com/content/dam/e- ... -01-EN.pdf
The wireless only I spoted it in several parts.
1 - Compatibility chart.
2 - ST-RX825/BR-RX820 Dealers Manual
https://si.shimano.com/en/dm/GADBR10/in ... trol_lever
3- GRAVEL Di2 Series General Guide
https://si.shimano.com/en/dm/GAGN001/around_cockpit
ultyguy
by ultyguy
Not an amazing chart reader…
So if I have a mostly Ultegra 12sp di2 and swap in the new grx crankset as well as the new grx FD, do I live?
harblhat
by harblhat
ultyguy wrote:
Sat Jun 29, 2024 7:38 pm
Yes. You may have to shorten the chain. The Ultegra RD is only supposed to be able to accommodate a 16t front tooth difference but it should be fine. The RD capacity also won't technically allow 11-34 cassette with a GRX crank but likewise it should also be fine.
ultyguy
by ultyguy
Cool, thanks! Yeah, I’ve seen a YouTube vid of a guy fitting a 105, 11-36 cassettte to Ultegra di2 successfully, I guess that’s not far off the same ratio either tbh.
