Canyon Inflite Gravel setup
la85
by la85
Hey all,
I bought a Canyon Inflite as an all round bike with a set of gravel wheels and road wheels.
Its running Ultegra and GRX front and rear.
Currently running 36/52t with a 11/32t.
What's the best set up for a gravel bike with 2 x?
I can get a 11/34t cassette.... should I down the front chain rings as I find I struggle with the 36t 32t on the steep stuff.
Cheers
jayjay
by jayjay
Do you struggle a lot with your current setup?
If yes, I would switch to a GRX crank with 46/30 or 48/31 and the 11-34 cassette. (GRX cranks need the GRX front derailleur!)
But maybe it would already be enough to change chainrings to 50/34 and to the 11-34 cassette.
kgcx
by kgcx
I'd just throw on the 48/31 grx crank and keep the 11/32 in the rear. I had an inflite with ultegra Di2 and had a 2x grx crank on the front. I was able to get the regular ultegra FD to work, it was just maxed out on the limit screw.
maurice1
by maurice1
Depends where you live and on your fitness. 48/31 11-40 is certainly not overkill where I live.
What is the lowest gear ratio you would need? I would preferably change for the grx cranks but a 11-36 or 11-40 cassette depending on what you have and need could be more versatile
la85
by la85
Thanks for all the advice.
I also have the 46/36t Ultegra chainring the bike came with.... I'm thinking of swapping the 36t out for a 34T (46/34T) and putting a 11-34t cassette on it.
Or would a 50/34t compact chainring with the 11-34 cassette be better?
Thoughts?
CampagYOLO
by CampagYOLO
Those GRX rear mechs will shift a 11-36 and even a 11-40 cassette fine, could be worth switching to one of those.
Pair a 11-36 cassette with a 50/34 crankset and that combo should be good for both gravel and road duties.
la85
by la85
Thanks!
