- https://www.cadex-cycling.com/global/sh ... x-ar-tires
https://www.cadex-cycling.com/global/sh ... x-gx-tires
Cadex AR and GX gravel tires reviews
Has anyone here tried the Cadex AR or GX tires? Online reviews are very hard to come by.
Yes, I see the similarities now between Cadex and Maxxis. Thanks for letting me know about the Challenge tires.
I was hoping to buy local and my shop has the Cadex tires in stock.
I think Cadex is made by Maxxis, if it wasn't clear. They're both made in Tiawan and use a 170tpi casing, which is unusual.geofharries wrote: ↑Mon Apr 24, 2023 12:14 amYes, I see the similarities now between Cadex and Maxxis. Thanks for letting me know about the Challenge tires.
I disagree with the Challenge tire - quality issues. I had a set and the tread wasn't adaquately secured to the casing at the edges.
The percentages don't matter, if there's significant gravel, there's significant gravel. For the off road portions- the rowdiness of the gravel matters - is it soft or hard surface, mud/sand, sharp rocks, etc.
That tire has the side knobs way off to the side in a place you'd likely never get to. You'd need to lean the bike waayy to the inside of the corners by bending your knees to a point you could only do on a MTB frame. Don't worry about centerknobs, if they're spaced close together, they won't hurt the road side and will help with punctures. For the gravel side, the percentages don't matter, the rowdiness of the gravel deal. For a 40c go with the usual suspects, mostly road tire G-One RS, Terra Speed, Tufo Thundero, Pirelli H
Thanks! I bought a pair of 40mm Pirelli Cinturato Gravel M tires. They had really good reviews for rolling resistance as well as puncture and grip scores, and seem to suit the intended terrain best (wet, loamy, rocky or paved).
Took them for a ride last night. Quite speedy on the road with the centreline tread blocks.
The only thing I heard, but not experienced, on the M was that the wide, heavy center lugs were a bit sketchy when you hit shallow mud and the big lugs don't do much on harder surfaces with higher tire pressures because it's a big 'tilt' till you enguage the lugs - basically the lugs don't work in some situations where you'd think they're optimized for. As long as you're running them soft or in chunky conditions, they should be doing what you expect.
