I'm looking to buy a Santa Cruz Stigmata. I'm 179 cm tall with shortish legs (inseam of around 81 cm), negative ape index (175 cm arm span) and longer torso and a saddle height of 715 mm. I can fit both 54 and 56 size road and gravel bikes (depending on the model/brand) and prefer a more relaxed position to an aggressive/racy one (I'm not too flexible, but I'm not a beginner either).
I've tested very briefly a size 56 Stigmata. It felt okay, and with slammed 85mm -8 degree stem (no spacers) or a 90mm -17 stem (with 15mm spacers underneath) & only 12-13 cm exposed seat post it would fit me perfectly (based on my ideal stack/reach). The 54 would give me the same fit/position with a 100mm -12 degree stem (on top of 25mm spacers) & more seat post exposure (around 15 cm, I reckon). Which one would you go for if you were me? Please, spare me the "if between sizes, always go for the smaller (as you can make a small bike bigger, but not the other way round)" type of advice (I have successfully made both smaller and bigger road bikes fit me, as I'm in between sizes). I can only get my favorite color in size 56, so that part is a no brainer. And a shorter stem (85-90 mm) is, in fact, ideal on a slacker HTA gravel bike these days. But I'm a bit worried about the short seat post exposure (standover height on the 56 is not ideal, but still within limits), though my current size 54 Spec Crux is almost the same (as it has a 540 mm seat tube comparable to the 545 mm of the size 56 Stigmata).
Help with sizing (in betweener)
I'd look for something else that has my desired fit. No point buying a frame knowing it's not ideal.
