How many spacers: 11-42 SROAD cassette on 11s Shimano freehub
saldegracia
by saldegracia
Hi all, I just want to confirm if I am just stupid for not using the right spacers on my freehub, or if there is actually something wrong with my cassette. I am using a SROAD 11-42 cassette on Shimano 11s freehub on my gravel bike, with a 1.85mm (8,9,10 speed) spacer. But is seems all sprockets, apart form the smallest one, are still very slightly wiggling under load. Do I need another spacer?
Canyon Aeroad, Votec VRC, Fuji Jari Carbon, Sensa Fermo SL, Principia R700, Cannondale Bad Boy Ultra, Ciöcc Singlespeed
Aesch
by Aesch
I had the same with a shimano cassette, it ended up to be my fault as I misplaced a spacer somehow in the middle of the cassette. Maybe check this, to be sure.
saldegracia
by saldegracia
Aesch wrote:
Wed Feb 08, 2023 7:35 pm
This cassette is all one block, plus the smallest sprocket, so there are no spacers between sprockets, only the one you put on the hub before you slide on the cassette. I know there are 1mm spacers, I am just wondering if I need to add one of those....
saldegracia
by saldegracia
I actually found a 1mm spacer today and added it, but no changes to the wiggling....I am starting to think the SROAD cassette spider is actually broken, which is kind of a bummer after only 8k km. Will try a new cassette when I get it and report back.
Erwin
by Erwin
The problem is sorted out yet?
saldegracia
by saldegracia
Hey, sorted...but not the way I thought :) The original spacer was all that's needed. On this occasion the cassette was actually broken, basically there was play between the spider and the cassette body, no amount of spacers would make that go away. I replaced it with a more convential Sunrace cassette and all is fine now.
Erwin
by Erwin
Ok, I understand. Thanks for your feedback. I have an Sroad cassette too, so I will have a look at it. 8k km are not that much, but time will tell. Perhaps I have more luck. The cassette is quite light and shifts well.
