It's a common issue. Try:FlatlandClimber wrote: ↑Wed Jun 21, 2023 6:58 amA technical question. I'll soon get the right size seat Post finally (I got the 350 initially, because the bike shop got everything mixed up).
My current seat post is therefore fully extended. However, I can't keep it from creaking and more problematically, slipping. It moves precariously front to back after a while, and definitely slides into the frame.
I have used the official Black Inc paste, and pretty high torque, but it seems the bolt is loosening or something.
Does anyone have a fix for that?
I hope that more seatpost inside the frame at least limits lateral movement.
Interestingly enough, Gran Fondo Magazin just tested the bike and reported the same problem.
- adding frame protection (or gorilla tape, or whatever) to the back of the seatpost to reduce clearance
- adding blue loctite (make sure you give it time to dry). I used the gel version that doesn't need a primer - when I tried the liquid one I had issues getting it to set.
I would do the two things above and it should be just fine. If not,
- if the grub screw is stainless steel you may contact Factor to get a revised model, in black, which appears to be better (but still comes with loctite).
- some folks have experimented with sandpaper with good results but I can't speak to that as much.
Be careful of not stripping the thread. Once you set it, forget it. If you need to remove the seatpost or adjust it, you will break the loctite bond and it might not stay in place.
