Carbon vs. Ti gravel bike?
Anyone else labored over the decision? Same build on each. Carbon (Argon Dark Matter) or straight gauge ti custom (US builder). Taking cost out of the equation...which is about $1k more for ti.
Seems like ti is old school. But, durable, a bit more damp/smooth, custom. Carbon, well, its carbon. Stiff, fast(er), light.
Not a primary bike, N+1. 1st world problems.
I'd go Ti. I have high end carbon currently (Parlee Z0-XD) but originally purchased as a do all bike so that drove my decision. It's a great bike no doubt, but if I was starting from scratch and just getting a gravel bike it would be Ti.
2024 BMC TeamMachine R
2018 BMC TImeMachine Road
2002 Moots Compact-SL
2023 Pivot E-Vault
2023 Pivot E-Vault
- Moderator
It's gravel.. you will crash/come off... which are you going to have more piece of mind getting back on and giving it the beans?.. metal just makes more sense
Allegra- Steel Lugs TBC
Aurelia- Stainless All Road 8.5kg
Bertha- TT 9.8kg
Perdita- Ti Turbo bike 8kg
Serenity- Ti Gravel 9.5kg/8.9kg
Verity- Ti Aero 8.2kg
Alya- Ti Climbing TBC
Bertha- TT 9.8kg
Well, the answer is it depends. If you already have a carbon primary bike I'd go with a Ti gravel bike. If you already have a Ti primary bike I'd go with a carbon gravel bike.
Both of my primary and secondary bikes are Ti so I went with a carbon gravel bike. Gravel bikes are damn heavy no matter the frame material. Either material choice is fine so I'd go with whatever material you currently don't own.
My road and mountain bikes are both carbon.
The ti builder gave a brief overview of dB vs straight gauge and I will explore more with him after deposit and we get 8nto build. Overall, if I want stiff (I ride a larger frame) vs light, ill go stiff and as he explained straight may be more beneficial. TBD.
Yeah. If your have a large frame the stiffer straight gauge tubes will be better. The weight saving of DB is very minimal. Usually only the top and bottom tubes are DB'ed. The seat tube is almost always straight gauge. Another alternative is to use larger diameter tubing but use DB'ed tubes. There are many possible ways to achieve the end goal.
Go Ti and natural brushed finish. Besides ride quality, It will look new after decades. Even if you don't crash, chips and scratches and nicks are inevitable with carbon. With ti, you just buff it out and it looks brand new. It's like magic.
I have a ti gravel frame and a carbon gravel frame. The geometry on both is virtually identical bar 3mm longer and lower for the carbon.
Both ride really well but the Ti is about 450g heavier than the carbon. Is that enough to bother you?.
As for Ti being a frame for life. Nope, they crack and fail just like anything else.
The finish gets scratched if you wipe off mud ( obviously depends where you live ) but they look worn just like any other frame after a while.
I'll be honest and say that when I clean the TI bike I'm meticulous at looking at all the tubes and welds for cracking or failures. I don't tend to be so meticulous with the carbon frames - I think I trust them more.
There is no magic carpet ride or springy feeling from Ti, I think that's just marketing / online review BS.
I've had a few of them now so it's not just the current frame.
I'm not being negative towards Ti, not at all. But I'm also not going to evangelise the stuff like it's a supernatural material.
I'm pleased I have mine and I wouldn't part with it.
