How much does your gravel bike weigh? (why are they so heavy?)
PaulJ
by PaulJ
darkmother wrote:
Wed May 24, 2023 10:31 pm
PaulJ wrote:
Mon May 22, 2023 10:30 am
It's the old style fork (the frameset is 2 years old). I was actually pleased when I realised I'd got one before the updated fork with mounts came out. I've no need for fork mounts and it made removing the paint in that area less fiddly.
To remove the paint was a pretty laborious process, but not technically difficult. The One-one paint was SUPER thick, 3 coats in places plus clear, so I did the bulk of the work with a blade scraping it off, then sanded with 400 grit wet. Sanding got through the paint pretty easily, it's the clearcoat which is the hardest. I airbrushed some small areas black to cover up some parts I didn't want to be seen or were too fiddly to remove all the paint, like round the drop outs, rear brake mount and bottle cage inserts. There was also a big sticker in the resin on the downtube with the frame details, so this got covered up too.
Thanks for the response. My frame is from Carbonda, and it appears to me that it has been painted flat black with no clear coat on top. I may try my hand at sanding the paint off-might be a good winter project.
I have MTB from On-One, and their branding leaves a lot to be desired from an aesthetic stand point. I can understand why you stripped yours bare.
I suspect that won't be too much work at all then. I used a 2k clearcoat when it sprayed it, with a compressor and gun. Had to flat the final coat back quite a lot (it was my first time using a compressor / gun setup) and polish but the results can pretty much be as good as the time you're willing to put in to this process!
Yeah, I only went for the On-one branded frame as it was the cheapest option. I originally spoke to Carbonda about buying a frame direct, but the unknown duties put me off. I saw PlanetX sell frames with paint defects on ebay with a discount, so just went for one of those as I knew I'd be stripping the paint anyway. It was the worst of the old colour schemes too - the red / yelloe / purple creme egg style. The new colours are much better, particularly the black.
warthog101
by warthog101
Pyotrump wrote:
Sun May 21, 2023 2:09 am
Cannondale Super X cx.
6.56kg with roadie setting. 11-28 cassette and 25c tires with tpu tubes.
LB'S AR25 rims are amazing.Image
Impressive :o 8)
Pyotrump
by Pyotrump
Impressive :o 8)
Thanks!!
I am planning to replace porky bottle cages(64g), barfly garmin mount(56g), two 6 bolt-cl adapters(60g) with something WWish.
나의 SM-G977N 의 Tapatalk에서 보냄
darkmother
by darkmother
PaulJ wrote:
Thu May 25, 2023 9:51 am
Thank you for your insight. I've never painted anything properly, however I could possibly make use of the shop air at my workplace on a weekend when no one is around.
TomSte
by TomSte
Cannondale Topstone Carbon Custom
8.15kg w/o pedals :thumbup:
kroem
by kroem
Waltly Ti. GRX/XTR/Hope mix. 8.765 kg (yea yeah no sealent... 🤪)
Current
Waltly Gravel (stolen... and found!)
P-X Spitfire Ti
Fairlight Strael
Old
Canyon Ultimate SLX 6.7kg (crashed)
Tantan GR039 7.2kg (sold)
trackflack
by trackflack
kroem wrote:
Mon Jul 03, 2023 2:41 pm
Always fancied getting a Waltly, that weight's pretty good for ti!
Thatsbullshark
by Thatsbullshark
2023 Boone. 17.9 lbs with cage and 38mm Vittoria Mix tires. 17.1 lbs with Enve/Challenge Limus tubs.
Pyotrump
by Pyotrump
Thatsbullshark wrote:
Sun Aug 13, 2023 2:04 pm
Nice pedal choice! it suits well.
Pyotrump
by Pyotrump
Sold my WW Cannondale Super X and bought Ventum GS1 2023.
I am planning to put 2" winter tires when Novembre comes.
Sram Red 22 hydro with Shimano 9100 front mech.
Sram Red Axs hydro calipers (current version)
S road 11-30 cassette,
Rotor Aldhu 165mm 50/34 DM rings
Assioma Uno pedals
LB AR25 rims paired with Bitex hubs
GP5k 32c (34.4mm WAM) with 40ml*2==80ml Muc off sealant
KCNC Razor rotors
A bike without lights is 6.65-6.7kg (14.66-14.77lbs for US guys Pheww...) I managed to weigh this with body weight scale.
maybe 7.1kg? I will visit LBS to weigh this again....
kroem
by kroem
Those DM Rings are NICE! Almost look refective :D
Current
P-X Spitfire Ti
Fairlight Strael
Old
Pyotrump
by Pyotrump
kroem wrote:
Mon Aug 14, 2023 7:43 am
Wow... you are the first person who complimented my "manually polished" silver DM rings.... I had to put clear coat on it due to its made of 7075 Al alloy which is prone to corrode and mechanically fail... Thanks again.
Thatsbullshark
by Thatsbullshark
Pyotrump wrote:
Sun Aug 13, 2023 2:27 pm
Thanks!! At first I was worried that the Xpedo pedals would clash with the frame but I think they look great! and hopefully shed mud better than SPDs
Tb205gti
by Tb205gti
Just bought a 3T Exploro racemax in 54/M and put it on the scales..
8.4Kg as it is right now. (it is a 2by setup, with Sram Force AXS)
The place i can "win" the most weight is probably in the wheels.
Wheels: Forza Levanto db Carbon
Hubs: DTSwiss 350
Tires: Panaracer GravelKing SS 700cx40
And by going 1by with a lighter crankset. :)
abLEmiaB
by abLEmiaB
TomSte wrote:
Thu Jun 08, 2023 7:31 pm
Love this. Gives me an idea how my lab build will end up. Yours looks great.
