Have anyone successfully make the gearoop work with the sram red etap axs?
I tried to install the 46-30t 8bolt on sram red etap axs groupset with no luck.
The FD can't move the chain from the small chainring to big, whatever i set the limit screw.
Sent from my SM-F721B using Tapatalk
Gearoop 44/28 direct mount chainrings 130g (476g full crankset)
I've faced the same issue the first time I tried to upshift. For me the solution was simple. I've just checked if the derailleur cage was parallel to the chainrings, twisting it ever so slightly that the bottom cage part was a bit in towards the frame (almost unnoticeable).
I'm on EPS though.
I'm on EPS though.
