if you keep going.. you are going to be doomed.. Stop!!!! yours is small i Am 100% sure about it and do not ask why...bobinski wrote: ↑Thu Jul 21, 2022 2:31 pmA question on sising. I have an opportuniy to buy an excelent condition medium. I am 175cm and inside seam of 77cm. Short legs and long torso and arms. Ridley's site suggests that i should ride a sise small. Anyone with similar measurements let me know what sise they ride? Mnay thanks.
Ridley Kanzo Fast
Pyotrump wrote: ↑Thu Jul 21, 2022 3:04 pmif you keep going.. you are going to be doomed.. Stop!!!! yours is small i Am 100% sure about it and do not ask why...bobinski wrote: ↑Thu Jul 21, 2022 2:31 pmA question on sising. I have an opportuniy to buy an excelent condition medium. I am 175cm and inside seam of 77cm. Short legs and long torso and arms. Ridley's site suggests that i should ride a sise small. Anyone with similar measurements let me know what sise they ride? Mnay thanks.
Small it is !
Yes. Small is your size for sure. Maybe XS If you like more aggressive position. Iam 184 with 84 inseam. I run a Size S slammed with Noah Cockpit (110/400).bobinski wrote: ↑Thu Jul 21, 2022 3:40 pmPyotrump wrote: ↑Thu Jul 21, 2022 3:04 pmif you keep going.. you are going to be doomed.. Stop!!!! yours is small i Am 100% sure about it and do not ask why...bobinski wrote: ↑Thu Jul 21, 2022 2:31 pmA question on sising. I have an opportuniy to buy an excelent condition medium. I am 175cm and inside seam of 77cm. Short legs and long torso and arms. Ridley's site suggests that i should ride a sise small. Anyone with similar measurements let me know what sise they ride? Mnay thanks.
Small it is !
FOIL 20 w/DA 9270 + ENVE 60/67 2023 wheels - GP 5000TR S 28MM
Ridley GRIFN, 105 Di2 12s + Nextie AGX45 (40mm wide) aerogravel wheels - Terra Speed 45mm
Turns out I am 174cm tall and 76cm so edging towards an xs in Ridley's site. As an earlier poster asks is there a potential issue with toe overlap?sunfire2k5 wrote: ↑Sat Jul 23, 2022 10:12 amYes. Small is your size for sure. Maybe XS If you like more aggressive position. Iam 184 with 84 inseam. I run a Size S slammed with Noah Cockpit (110/400).bobinski wrote: ↑Thu Jul 21, 2022 3:40 pmPyotrump wrote: ↑Thu Jul 21, 2022 3:04 pmif you keep going.. you are going to be doomed.. Stop!!!! yours is small i Am 100% sure about it and do not ask why...bobinski wrote: ↑Thu Jul 21, 2022 2:31 pmA question on sising. I have an opportuniy to buy an excelent condition medium. I am 175cm and inside seam of 77cm. Short legs and long torso and arms. Ridley's site suggests that i should ride a sise small. Anyone with similar measurements let me know what sise they ride? Mnay thanks.
Small it is !
Hello,
Small question about the standard seatpost include in the frameset. Can I mount a carbon oval rail saddle on it ?
Anyone know what the max chainring clearance is? This seems like it would be a candidate for n-1 road and gravel.
How are your bikes holding up? I saw some quite concerning stuff on YouTube about the headtube scratching the frame etc. https://m.youtube.com/shorts/dLxmOCu7lEU
My frame is scratched there as well. My first ride was in HORRIBLE weather (and a long one), and it got scratched on the headtube like in the video.
Applied clear protection film on it after that ride, should have done it before. So yes, it scratches there but can be solved with some protective clear film.
Otherwise, love the bike. Came from a Canyon Grail CF SL, and like this one a bit better. Both bikes are brilliant, but the Kanzo for me wins because of seating position (I have a narrower bar and stem combo from the Noah Fast). Also the bike looks the part....
Not sure what the max is, I run a 42T at the moment which has a lot of clearance still.andrewbn42 wrote: ↑Thu Mar 16, 2023 2:46 pmAnyone know what the max chainring clearance is? This seems like it would be a candidate for n-1 road and gravel.
k33z wrote: ↑Mon Mar 20, 2023 10:49 amMy frame is scratched there as well. My first ride was in HORRIBLE weather (and a long one), and it got scratched on the headtube like in the video.
Sounds positive! Is yours on the classified hub as well?
Would it clear something like a 50 though? I like the 48-50 chainring with a mullet combo for fast gravelk33z wrote:Not sure what the max is, I run a 42T at the moment which has a lot of clearance still.andrewbn42 wrote: ↑Thu Mar 16, 2023 2:46 pmAnyone know what the max chainring clearance is? This seems like it would be a candidate for n-1 road and gravel.
FYI, Ridley website allows you to configure Classified version with a 48T Rotor chainring.andrewbn42 wrote: ↑Wed Mar 22, 2023 7:12 pmWould it clear something like a 50 though? I like the 48-50 chainring with a mullet combo for fast gravelk33z wrote:Not sure what the max is, I run a 42T at the moment which has a lot of clearance still.andrewbn42 wrote: ↑Thu Mar 16, 2023 2:46 pmAnyone know what the max chainring clearance is? This seems like it would be a candidate for n-1 road and gravel.
Thanks for the info. I had been looking at data sheet and it didn’t specify, but I didn’t do thatLell87 wrote:FYI, Ridley website allows you to configure Classified version with a 48T Rotor chainring.andrewbn42 wrote: ↑Wed Mar 22, 2023 7:12 pmWould it clear something like a 50 though? I like the 48-50 chainring with a mullet combo for fast gravelk33z wrote:Not sure what the max is, I run a 42T at the moment which has a lot of clearance still.andrewbn42 wrote: ↑Thu Mar 16, 2023 2:46 pmAnyone know what the max chainring clearance is? This seems like it would be a candidate for n-1 road and gravel.
