LeManchot wrote: ↑Mon Jul 10, 2023 9:58 pm
Yes, based on the volume of riding I do, I often have to bleed the brakes every couple of weeks and have communicated this to the shop where I purchased the bike and to Campagnolo. The attiude from the shop and Campy has been, let's say, not inspiring. My local shop (not the shop where I bought the bike) doesn't use the Campy bleed process and, so far, I am seeing better performance (up to 2000 km and counting on thier bleed of my brakes). Time will tell. Glad to hear that you have not experienced any bleed issues and let's hope that that continues!
Why are you bleediung the brakes?
Are you seeing any fluid loss and / or are the brakes "going spongey"?
This really pought to be addressed by the retailer who set the brakes up initially - hiowever, I think there are a lot of shops out there now without good training on hydraulics and whilst they may be able to do a vanilla installation, if they make a mistake they don't have enough knowledge to recify it.
I've set up well into the 100s of Campagnolo disc brakes now and not yet seen a serious issue.
Suggestions are:
1. On a newly bled system, before reassumbling pads and wheels, with the bleed blocks in place, put two strong rubber bands around the levers to pull the brakes hard "on". Leave overnight and inspect. If there are traces of oil at the banjo on the lever, at the bleed nipple or caliper union, you have a bad seal at those locatioons.
If it's a really slow leak, sometimes this overnight test is needed to identifty it. This is "hydraulics 101" but a lot of shops / techs don't do it.
If the leak is very small, the lever position relative to the handlebar will barely change so a close look at the likely leak points is needed.
If the levers have moved, it's also worth inspecting the hose close to the banjo and to the caliper. It is possible, most probably at the caliper's olive / barb union (I have never seen the factory-fitted banjos allow this to happen), that fluid has forced it's way between the plies of the hose - this is most likely to happen where the cut end of the hose is not dead square, ragged, or the barb is not fully home in the end of the hose. In this case the system will gradually lose fluid but there will be no external leak visible. Such leaks can be very slow so a hose check is worthwhile in any ase, if you have had a long term problem with this.
2. If the system is being re-bled because it is becoming spongy, check that the caliper is still pulling centrally on the rotor - the sponge that you feel may be one piston pushing the rotor across to meet the other, possibly slower-moving or even seized piston - this will delevlop slowly over time as one pad will weare faster than the other and it will appear to be fixed by bleeding as that will re-centre the pistons either side of the rotor after the initial pump up.
You'll be able to see this in a fully assembled system, by simply looking at the edge of the rotor as you pull the brake on - the rotor should not move at all, axially, as the brake is applied.
3. Check that the brake mounts ahve been faced so that the brake is sitting on a hard, square surface, not paint. Paint can squirm or crack, alloowing the caliper to move about, so causing a de-centring effect.
If all of the above fails to resolve, return the caliper(s), lever(s) and hose(s) to the market SC for full assessment under warranty.
If this is happening to both brakes, I'd lay very long odds that it's anything other than an installation issue of some sort.
