Ceramicspeed BB dust cap removal
Rotalution
by Rotalution
Hi WW,
Anyone with tips to remove the BB integraed dust cover cap without buying this tool from CS?
https://ceramicspeed.com/products/ceram ... rvice-tool
Video on how to use the above tool and remove the dust cap.
https://youtu.be/BZrxfgTIxl8?t=25
Thanks ~~
mathemagician
by mathemagician
It looks like you could just tap the cover out with a screwdriver from the other side- just be gentle and work around the circumference of the dust cover as you tap. If you're scared of breaking something then use an internal bearing puller with the right tip size.
Sent from my CPH2207 using Tapatalk
Rotalution
by Rotalution
Thank you for your advice
Sent from my SM-N9860 using Tapatalk
