Campagnolo EPS V1 repair
karts22
by karts22
So, the power unit isn't holding much charge anymore and I'd like to change the battery inside it. Can anyone advise what type of battery is used, I don't want to take it apart before I have the replacemant.
Butcher
by Butcher
I'm surprised you have a v1 that still works. My original one lasted a week and the second one was replaced once they had v2.
I would look into finding a v2 and once you know you can buy one, take yours apart and report back on your findings. Take a lot of pictures.
glepore
by glepore
I'd be seriously afraid of anything v2 at this point. My v2 bike is on 10 hrs ride/charge cycles, and my choice is something over 1kusd in parts ( it chorus/athena) to make it work with the current v3 battery (actually a v4 w/ the right firmware to make ti work w/ v3) or to solder a bunch of hair thin wires. There are used v2 batteries available but their health is a question mark.
Cysco Ti custom Campy SR mechanical (6.9);Berk custom (5.6); Serotta Ottrott(6.8) ; Anvil Custom steel Etap;1996 Colnago Technos Record
Butcher
by Butcher
That is true, batteries will eventually stop working.
My v2 is at least 10 years old and since my is hiden inside my handlebar stem, I cannot see what lights are indicating. In those 10 years, I have only had a low battery issue once. Fortunately, it was on the trainer. Other than that, I charge mine up when I feel like it. Usually every few months.
I do have a new Athena EPS groupset that the battery is regularly charged up. Someday, it's suppose to go on my rain bike.
joeyb1000
by joeyb1000
karts22 wrote:
Mon Jun 10, 2024 7:51 pm
Please post info when you do it.
I don't know what battery the v1 used. V3 uses three 14400 batteries. I am betting that v1 also uses the same or, at least, some other generic battery.
ferrarista
by ferrarista
I remember opening one long time ago. It had pouch cells. They went with round cells when they changed to v2 to be able to fit inside the frame.
I don't recall the space inside, but should be able to fit some round cells I think.
