ENVE Fray build
pmprego
by pmprego
patchandscruff wrote:
Thu Apr 25, 2024 9:08 am
The new D2 shifters are visibly more angled that the D1s. I’ve just measured the very bottom of the levers centre to centre and they are…42cm!
I’ll get a photo at some point and post it up.
Thks
Yoln
by Yoln
As someone who has ridden campy 13x a lot over the past 3 years, both in chunky gravel and very light / all road configuration. I am not sure than 13s is what you want.
As much as I love my setup with 42s or 47s for real gravel rides where range of gear is the key. The 13s is simply not good enough yet as an all-road 1x. Jumps are still too big for my taste, I don't think I will consider 1x on an all road bike until 14s.
As far as tires too, if you're going to ride corsa pro 32mm, you probably don't even need a Fray, why not go for the Melee?
#RETIRED# Lynskey “the Do-it-all Helix” 🧬:https://tinyurl.com/bdmb5y24
B0tt0mline
by B0tt0mline
Yoln wrote:
Thu Jun 13, 2024 1:31 pm
Geometry and looks :)
Colnago C68- Enve SES 4.5
S-Works Aethos - Enve SES 2.3
Enve Fray - Enve SES AR 4.5
Open MIN.D - Enve SES AR 4.5
Mosaic GT2-45 - Enve SES AR 3.4
Chinese Winter/Rain Bike
counterintelligence
by counterintelligence
B0tt0mline wrote:
Thu Jun 13, 2024 7:48 pm
Same here. I ride a Melee with exactly 20mm of spacers. The Fray happens to be 20mm taller than the Melee AND I intend to run the 13sp Red XPLR when it comes out so UDH is required. Just waiting for more info on the group and general availability and I'll be switching. I also plan to run 34mm road tires on a 27mm internal rim so I'll be close to / over the tire clearance Enve recommends as the 34s will end up wider than 35mm on that setup (Melee is listed as up to 35mm clearance but i know people have fit wider in there).
B0tt0mline
by B0tt0mline
counterintelligence wrote:
Fri Jun 14, 2024 12:45 am
1:1 like myself.
I will built it up with the new RED levers and Force XPLR 1x. Will then switch to the 13s when it is available.
counterintelligence
B0tt0mline wrote:
Sat Jun 15, 2024 9:20 am
1:1 like myself.
There are two of us! I'm currently running Force 1x with the 48t aero chainring, the XLPR RD and the 10-44 cassette. I love the setup, I don't find the jumps too big / unmanageable as is. I'm sure the 13sp will be even better - very excited to get the full info on how Transmission is being adapted for road.
Requiem84
by Requiem84
Has anyone in Europe already found a reasonably nice price reduction for a framekit?
So far the best I have seen is EUR 5,524 on Ciclimattio.com. That's still pretty steep. Was hoping to find a much better deal eventually :D
