Cervelo S1 usual crack... Second owner... what to do ?
kantonin
by kantonin
Hi !
I got a second hand S1 that was cracked... only very small it's the begining of the usual crack we seen a lot...
as I'm not the first owner I can't warrany replace it...
So as it's very little is it safe to drill a larger hole at the existing hole place to stop the crack? Or it's better to leave as it is and check... ?
previous owner doesn't use the cervelo shim maybe this cause the crack (the shim has fall far inside the seat tube)
Thanks for advices !
robinbatman
by robinbatman
Repair
Have it repair
Or it will get worse
Or just hang it off the wall
If you have someone qualified who can do a cost effective repair and you wanna keep riding it , do it
