Does an SRAM XG-1150 need a lock ring?
Just noticed something weird on my Sram XG-1150 (10-42) cassette- it doesn't have a lock ring present, and just a loose shirt pipe holding everything together.
Is this normal please?
As when doing a road side tyre repair, the cassette easily slides off!
The lockring is integrated and done up with the usual cassette tool. It should never be sliding off the freehub body.
Yeah sorry for the confusion, I meant the freehub body easily slides off, along with the cassette screwed on to it.CampagYOLO wrote: ↑Tue Mar 12, 2024 4:52 pmThe lockring is integrated and done up with the usual cassette tool. It should never be sliding off the freehub body.
Not sure why SRAM went with this design, much prefer the Shimano in this case!
Sorry- I meant the freehub body easily slides off, along with the cassette!CampagYOLO wrote: ↑Tue Mar 12, 2024 4:52 pmThe lockring is integrated and done up with the usual cassette tool. It should never be sliding off the freehub body.
The end caps just slip on, so they easily slide off too.
Am I understanding you correctly?bmcman wrote: ↑Wed Mar 13, 2024 7:45 pmYeah sorry for the confusion, I meant the freehub body easily slides off, along with the cassette screwed on to it.CampagYOLO wrote: ↑Tue Mar 12, 2024 4:52 pmThe lockring is integrated and done up with the usual cassette tool. It should never be sliding off the freehub body.
The freehub body easily slides off (detaches from) the wheel hub?
If so then it's nothing to do with SRAM and everything to do with the design of the hub.
Right, so that's what I said was happening. The freehub is coming off the wheel, and it has absolutely nothing to do with the design of the cassette or anything SRAM did (unless your wheel is also made by SRAM).bmcman wrote: ↑Wed Mar 13, 2024 7:45 pmYeah sorry for the confusion, I meant the freehub body easily slides off, along with the cassette screwed on to it.CampagYOLO wrote: ↑Tue Mar 12, 2024 4:52 pmThe lockring is integrated and done up with the usual cassette tool. It should never be sliding off the freehub body.
Tool free freehubs that are held onto the wheels by friction fit endcaps are quite common now, some with tighter endcaps than others. Along with heavier 1x cassettes a looser endcap makes it a lot easier for the weight of the cassette to slide the freehub off when you don't want it to. You could try cleaning everything up and reinstalling, you could try getting a new set of endcaps for your wheels in case they're at all worn, you could check if there are any seals that need to be clipped into place to provide an extra bit of retention. Ultimately though you might just need to remember not to put the wheel cassette side down.
The obvious question then is what are your wheels?bmcman wrote: ↑Wed Mar 13, 2024 7:45 pmYeah sorry for the confusion, I meant the freehub body easily slides off, along with the cassette screwed on to it.CampagYOLO wrote: ↑Tue Mar 12, 2024 4:52 pmThe lockring is integrated and done up with the usual cassette tool. It should never be sliding off the freehub body.
As stated by other posters this isn't a fault of the cassette and the end caps should be holding everything in place.
