MrWings
by MrWings on Fri Mar 08, 2024 1:17 pm
Hey people. Has anyone put 32mm wheel
width on their System Six? I’ve been looking at Light Bicycle WR65’s and these are 32mm external. I believe the ENVE 4.5 SES is also 32mm external too
Thanks in advance
req110
by req110 on Fri Mar 08, 2024 2:31 pm
32mm external width is what the systemsix was build around. Those knot64 are part of the system. So go ahead.
SW SL8 RTP 56cm @ 9270 / CLX II / CS OSPW / CEMA BB
S Epic 8 L @ XX T-Type / Berg Ratheberg 30 / Quarq / Fox Transfer SL 100mm / 3p
MrWings
by MrWings on Fri Mar 08, 2024 2:53 pm
req110 wrote:32mm external width is what the systemsix was build around. Those knot64 are part of the system. So go ahead.
Sorry I should have added the internal diameter as well
. They’re 25mm internal and 32mm external
cobc11
by cobc11 on Fri Mar 08, 2024 5:16 pm
definetly works but keep an eye on tire clearence. I ran ENVE SES 4.5s with 30mm vittoria tires and they blew up to just under 32mm. Cleared the frame and fork but with only 3mm of clearence on each side.
AJS914
by AJS914 on Fri Mar 08, 2024 5:41 pm
req110 wrote: ↑Fri Mar 08, 2024 2:31 pm
I think those knot64 wheels had a 21mm inner diameter. The Light Bicycle rims have 25mm. Any tire on those will a wider external width.
MrWings
by MrWings on Fri Mar 08, 2024 9:49 pm
cobc11 wrote: ↑Fri Mar 08, 2024 5:16 pm
That's handy to know. Did you try them with any other tyre too?
MrWings
by MrWings on Fri Mar 08, 2024 9:51 pm
AJS914 wrote: ↑Fri Mar 08, 2024 5:41 pm
Yeah exactly, I'd thought I'd check before I buy them. I'm hoping to put an order together this weekend
MrWings
by MrWings on Fri Mar 08, 2024 9:53 pm
Hexsense wrote: ↑Fri Mar 08, 2024 6:11 pm
Does this answer your question?
Light-Bicycle WR65+ 28mm tires with SystemSix
Nice bike! Few questions.... what do you think of the wheels? What build did you do? Why did you go for shallower on the front? What tyres exactly are you running and hows the clearance?
Hexsense
by Hexsense on Sat Mar 09, 2024 12:08 am
MrWings wrote: ↑Fri Mar 08, 2024 9:53 pm
They are great.
When I own SystemSix, I had 2 sets of front wheels: AR56 and WR65. And one rear wheel: WR65.
Pictured is 56/65. But I actually ride WR65 front and rear a lot more often. It's really rare that I look into weather forecast and see over 20 km/h wind and think "yeah, better ride a little shallower front wheel today".
I tested various tires. Michelin Power Cup 28mm, Specialized Turbo Cotton 28mm, and multiple sets of Continental GP5000 28mm.
All of them have plenty of clearance. Michelin is the biggest tire if I recall correctly.
MrWings
by MrWings on Sat Mar 09, 2024 8:12 am
Hexsense wrote:MrWings wrote: ↑Fri Mar 08, 2024 9:53 pm
They are great.
Brilliant! What spoke count did you go with on the rear? 24 or 28 and what offset did you buy?
Thanks
MrWings on Sat Mar 09, 2024 8:12 am, edited 1 time in total.
MrWings
by MrWings on Sat Mar 09, 2024 7:23 pm
MrWings wrote:Hexsense wrote:MrWings wrote: ↑Fri Mar 08, 2024 9:53 pm
They are great.
Brilliant! What spoke count did you go with on the rear? 24 or 28 and what offset did you buy? +3, 3 or -3mm
Thanks
Hexsense
MrWings
by MrWings on Sun Mar 10, 2024 8:37 am
Hexsense wrote: ↑Sun Mar 10, 2024 2:19 am
centered 24 spokes
Thanks for the info, I'll be ordering these this weekend. I'm just asking if I can change the colour of the hub (chris king r45d). I also want 20 spokes on the front too
