LRB23
by LRB23 on Sat Feb 24, 2024 10:10 pm
skinnybex wrote:Cervelo R5 - My size Medium built up with Sram Force Derailleurs and shifter/brakes, Sram Red Cranks, Chainset and Cassette and a Canary Avian bar with 45mm carbon spoked wheels is 6.35kg. All in this bike cost me about 7k to build from the frame set since plenty of good deals. The bike climbs as good as anything and the handling is A+
I’m in a similar position looking to build a light weight specced climbing bike. I’d began with looking at the Emonda SLR and after watching Rides Of Japan, I was convinced the Emonda was the way to go. BUT my Trek dealer told me to hold out and until the new Emonda launches this summer. The problems is I need a new bike now as I spend 6 months of the year away at work.
And that’s where the R5 comes in. I hadn’t considered it until today and now it’s looking like a hot contender. Could you tell me a little more about your build and any special components you used to get the weight down. Which wheels did you use? I’ve seen the Avian handlebars and they seem really light!
skinnybex
by skinnybex on Mon Feb 26, 2024 8:47 pm
LRB23 wrote: ↑Sat Feb 24, 2024 10:13 pm
Can you post some pics of your R5 when you have time
No new photos since I swapped to the Avian Canary. The bike in the pic with the stock Cervélo bar and 120mm stem weighed 6.74kg with pedals, Cages and Garmin mount. The Avian, Saddle and seat post saved me 400 grams.
Wheels are Farsports Hyper 45mm carbon spoked
23’ Cervelo Soloist / 6.88kg - 1x Crit Bike
22' Cervelo R5 / 6.35kg - Climbing Bike
22' Cervelo Caledonia 5 / 7.55kg - Travel Bike
21' Cervelo Aspero / 8.06kg - Gravel Travel Bike
23' Cervelo Aspero 5 / 8.25kg - Gravel Race Bike
MarkoP
by MarkoP on Mon Feb 26, 2024 9:12 pm
CampagYOLO wrote: ↑Sat Feb 24, 2024 7:57 am
RSJago wrote: ↑Fri Feb 23, 2024 9:13 pm
BalticSea wrote: ↑Thu Feb 22, 2024 12:46 pm
What's your budget?
Tifosi isn't something I'd buy, instead I'd try to find identical frame from the actual factory (i.e. their aero frame is just rebranded Yishun).
With that said, Elves Vanyar 2024, Winspace SLC 2.0 are good choices IMO, or maybe even Delihea Tank if you are on super tight budget (~900g frame based on, but not a replica of SL7)
I've got 650 so far with all the bits I have sold, still to sell a Ribble SL rim brake frame and my enduro MTB, which will all go to the final build, I can get a large mons intergrated frame new for 600 which I think is a good buy as I want to keep the rest of the budget for wheels, group set etc I think I can go quite light, and I'm happy on 28s
If you're talking pounds or euros then I'd strongly advise going second hand. Things are going really cheap on the second hand market right now, it's nothing like it was during COVID..
I'm still not seeing this but everyone keeps saying it. Maybe it's more specific to certain regions. Certainly it's nothing like Covid but I'm still not seeing a huge drop, at least not for modern builds from the past 4-5 years. I'll stay patient...(looking for a decent-ish bike for rainy days, off-season rides, trainer bike)
Current: 2021 Bianchi Specialissima I 2021 Tarmac SL6 S-Works (Sagan Edition) l 2023 Aethos S-Works
CustomMetal
- Moderator
by CustomMetal on Mon Feb 26, 2024 9:35 pm
Aurum Magma
Allegra- Steel Lugs TBC
Aurelia- Stainless All Road 8.5kg
Bertha- TT 9.8kg
Perdita- Ti Turbo bike 8kg
Serenity- Ti Gravel 9.5kg/8.9kg
Verity- Ti Aero 8.2kg
Alya- Ti Climbing TBC
LRB23
by LRB23 on Thu Feb 29, 2024 1:01 am
skinnybex wrote:IMG_5192.jpeg
That’s really nice. Pretty much the same build as I have configured but with Ultegra. Were you not tempted to go with the 35mm Hypers?
Can you confirm which Avain you ordered OD1 or OD2? How is the Canary? Are you noticing a lot of flex?
It’s crazy how much you can save with those three components.
Do you rate the R5?
skinnybex
by skinnybex on Thu Feb 29, 2024 6:56 am
LRB23 wrote: ↑Thu Feb 29, 2024 1:01 am
Do you rate the R5?
I originally ordered the 35mm Hypers but was later told the spokes were back ordered 2-3 months so I went with the 45's
Avian is OD1, it feels a bit flexy when sprinting for me but not overly negative for me. I max out around 1,050 watt peak so not a huge sprint for my 75kg
The R5 is my 2nd favorite bike I've ridden after my Soloist. For a pure handling perspective and light weight it's one of the top 3 bikes IMHO. I've ridden or owned SL6,7,Venge,Evo3,Evo4,Dogma 8-10-12 and Scott Addict RC so I've had some great race bikes
kofsw4
by kofsw4 on Thu Feb 29, 2024 9:44 am
Would also love to see a pic of your R5 with avian cockpit. Did you use a wedge insert for the D shaped steerer?
I'm considering getting the Falcon for my Cal5 which I think uses the same spacers/stem.
LRB23
by LRB23 on Thu Feb 29, 2024 6:00 pm
skinnybex wrote:LRB23 wrote: ↑Thu Feb 29, 2024 1:01 am
Do you rate the R5?
Thanks, I really appreciate your input. I’m a bit of Trek fan boy and wanted to do an Emonda build but the current version is getting long in the tooth and the new one is around the corner but too far away for my next build.
The more I look at the R5, the more I want one. It looks like it can handle wide tyres up to 34mm? I’m really torn between the Oxblood and the mat black…
If you get a chance I’d love to see your set up with the Avian bars.
Thanks again.
skinnybex
by skinnybex on Thu Feb 29, 2024 10:14 pm
I'll be back home March 13 and can post some pictures then of the Avian. I had them 3d print the spacers which fit perfectly when I ordered the bar. I'm on my way to Lisbon and then Algarve for some work and riding after but unfortunately looks like rain for my 4 days of riding
LRB23
by LRB23 on Thu Feb 29, 2024 10:42 pm
Does anyone have any good recommendations for BB’s? I’m not familiar with BBright. I’m looking for something suitable for DUB standard, using an after market crank
skinnybex
by skinnybex on Fri Mar 01, 2024 5:04 am
LRB23 wrote: ↑Thu Feb 29, 2024 10:42 pm
BBinfinite make some great Bottom Brackets. I'd recommend any of theirs before other brands if you want to only buy it once.
Sander7721
by Sander7721 on Fri Mar 08, 2024 1:24 pm
skinnybex wrote: ↑Fri Mar 01, 2024 5:04 am
Hey Skinnybex
Now I am readimg your posts to be nosey lol
I was goimg to recommend Hambini BB's as this is what I use but however as usual his BB's are out of stock!
https://www.hambini.com/crankset-type/dub/
SL8 Maganta 54CM 6kgs
Winspace SLC 2.0
