Where is new SRAM Red?
mfa81
by mfa81
Clemensa wrote:
Wed May 29, 2024 7:36 pm
Does anyone know if the new (larger) pulley wheels also fit the previous version rear derailleur?
not sure, but the entire cage should
mfa81
by mfa81
THe rest of my groupset finally shipped! :-D
Clean39T
by Clean39T
Got both of my full groupsets already.. Why two? Well - on the day it came out there were some coupons floating around at online retailers that worked when they probably shouldn't have.. and I ordered from two different places figuring one of them might get clawed back. Of course neither did. And now I have the choice of returning, reselling, or picking up another frameset :noidea:
alanyu
by alanyu
Found a good stuff fron Xianyu
7.4V 500mAh battery with refined pcb and handmade carbon shell.
Ronin416
by Ronin416
alanyu wrote:Found a good stuff fron Xianyu
How much?
thematzie
by thematzie
I don't know if this video is already named before. If yes, then I'm sorry, I don't want to bother you all.
The guys from Rad Race (Hamburg Germany) met at SRAM Germany to buod a bike with the new SRAM Red AXS. They had an absolutley interesting and detailed interview with the tech guys from SRAM about the new group. Link below.
https://www.youtube.com/watch?v=g_l_olZqr7E
mikehhhhhhh
by mikehhhhhhh
ArtV
by ArtV
Let the counting begin...........
Karvalo
by Karvalo
Roel W wrote:
Thu May 16, 2024 9:22 am
Lever design is a big improvement.
Previous lever designs and competitor lever designs have been based on the fact that the mechanical shifting mechanism had to be included in the housing.
Position of the hydraulic cilinder is completely different. Very clever design improvement.
Errr, so where is the piston in a Shimano DI2 lever then?
mfa81
by mfa81
mikehhhhhhh wrote:
Thu May 30, 2024 9:06 pm
13 speed spotted at Unbound
https://www.cyclingweekly.com/news/sram ... und-gravel
curious to know what's the cassette range!
OtterSpace
by OtterSpace
Karvalo wrote:
Thu May 30, 2024 10:29 pm
I cant find a cutaway image but here is a ST-R7170 teardown.
https://youtu.be/fRDcRtkHViY?t=407
Nice, love to see it :beerchug:
the mounted rear cassette looks to be somewhere around 46t.
raggi
by raggi
I have a Rotor 2inpower direct mount road crankset lying around and I am entertaining the idea of building up a 2x all road bike using that and the new sram red groupset. Can anyone inform me what I need to look at with regards to the chainline?
Just from comparing specs the new sram red crankset has a 45mm chainline vs 43.5mm on the 2inpower. Will this mean problem with shifting or is this something that can be adjusted using offset chainrings? Or will it maybe not be a problem at all?
stalkersk
by stalkersk
Why would there will be problem with shifting, Sram has currently standard and wide offering which is 2.5mm outboard and it shifts well with either if setup correctly. Only thing is if there is enough adjustment in the front derailleur for your chain line.
trackflack
by trackflack
13 speed might be enough to convince me to go 1x
trackflack
by trackflack
Wonder when shimano will catchup
