New Look 795 Blade RS
njleach
by njleach
Pugrot wrote:
Tue Apr 02, 2024 1:33 am
140*380 EXS bars on.
:thumbup: Any problems fitting the EXS Aerover bar? Close up of the bar and spacers? Did you just use the spacers that came with the bike?
Pugrot
by Pugrot
This was using the EXS ACR spacers, bit of a gap between the frame and cover that closed up to about 1mm under compression.No other issues, will probably try and find a better fitting cover for it and pull some spacers out to get lower once I'm used to the bike.
njleach
by njleach
Pugrot wrote:
Tue Apr 02, 2024 4:18 am
Very clean with the Aerovers and a lot more cost effective!
Look forward to hearing what you think of the 795 - I've been very happy with mine and have zero complaints :beerchug:
mjw00
by mjw00
BikeEatSleepRepeat wrote:
Thu Nov 16, 2023 3:00 pm
The magnet works well when the stem is cut close, but any excess space between and not so much.
The double sided tape is a good idea, but also make sure the lower/back clip is inserting fully engaged with the top spacer.
I managed to lose my headset cover. Look Australia cannot provide a date to provide a replacement - can anyone suggest an alternative source / vendor?
I'd also like to buy a spare derailleur hanger - any suggestions for a vendor for this? (A Shimano direct mount hanger would be preferred - any suggestions?)
Thanks in advance
njleach
by njleach
mjw00 wrote:
Wed Apr 10, 2024 3:02 am
Thanks in advance
Yes - ciclimattio - contact them directly and one of their sales reps will be able to order both items directly from Look for you.
I currently have both items on back order and they are due to arrive mid-April. Hanger = 20.49 euros, headset top cap = 21.31 euros. HTH
jlidds
by jlidds
Thanks in advance
If you PM me I can assist wwith a headset cover I think.
Tarmac S-Works SL6
Tarmac S-Works SL7
Tarmac S-Works SL8
Venge S-Works
Look 695
Look 795 Blade RS
Aurum Magma
Time Alpe d'Huez 23
No 22 Aurora
Wilier Filante
Factor Ostro II
Hapsmo911
by Hapsmo911
Can anyone offer an opinion on the geometry? Mostly how the bike feels (subjective) with the steeper seat angle compaired to other bikes youve riden. I like a steep seat angle and longer reach this seems like the perfect geometry.
mjw00
by mjw00
njleach wrote:
Wed Apr 10, 2024 4:48 am
Thanks in advance
I tried ciclimattio and they were unable to help me. Did you order the hanger for the 2024 version of the 795? Do you have the Look part number for it? Many thanks
njleach
by njleach
mjw00 wrote:
Sat May 18, 2024 11:02 am
Yes definitely for the new Blade RS - below are the part numbers that were on the invoice, not sure whether these are Look or Ciclimattio P/Ns but hope they are of assistance:
237997001001 - LOOK Blade 2 RS Forcellino Cambio Nero (Derailleur hanger)
868993001001 - LOOK Headset Top Cap Nero
ferrousfan
by ferrousfan
Hi WW Team,
Im looking at purchasing a Small size 795 Blade.
Question on bar width....
LOOK website specs the Small size frame with 40cm bars.
Can anyone inform what the bar width (C to C or Outside to outside) is at the brake hoods is for the Small size frame?
Do the bars flare out in the drops? how wide C to c at end of drops?
thanks in advance.
smv81147
by smv81147
My 795 Blade RS frame size S just arived with its 400 x 100mm handlebar. As I have not mounted it yet, I can give you the exact dimensions you are looking for:
Bar Top CC:40cm
Brake hoods CC: 41cm
Drop bar ends CC: 42cm
smv81147
by smv81147
Hapsmo911 wrote:
Fri May 10, 2024 2:26 am
I rode mine for the first tile today. Compared to other bikes I own it feels more aggressive, you sit more lower and with more weight on the front bars. Have to say all 3 bikes are set identical to the mm acuracy in seat height, setback, stack and reach... etc.
My other bikes : Merida Scultura Team and Wilier 0SLR
ClydesDale
by ClydesDale
Totally digging the white Mondrian scheme Look/Cofidis is using for the TDF....
smv81147
by smv81147
ClydesDale wrote:
Fri Jun 28, 2024 2:25 am
Nice color but prefer my black Iconic... besides, what is wrong with Look. Are they going backwards and ofering a DA 11speed di2?… check the specs here: https://www.lookcycle.com/gr-en/product ... white-r50d
Pugrot
by Pugrot
Garmin Edge 1050 fits the standard mount that comes with bars (just). In case anyone wondering.
