Poor rear shifting when on large chain ring
goldmine848
by goldmine848
Using Campy Chorus 11-speed mechanical system.
I have had a long-standing issue getting the rear shifting right when the front is on the large chain ring.
We have tried literllay everything inc;luding: adjusting cable tension, replacing cable, swapping out rear derailleur, and checking hanger alignment. Nothing seems to work.
It's not everry shift but most in the middle of the cassette are not smooth and regularly hang up or over shift. But only when chain is on the large ring.
Any thougths would be appreicated.
Sock3t
by Sock3t
Tough to diagnose when you don't list any information beyond groupset.
rudye9mr
by rudye9mr
Different rear wheel as well?
X5SAE
by X5SAE
Did you check chain length as well?
Road
Cube Agree C:62 SLT 2021 (frame+fork) DA 9270 6.9x kg - ride-ready 7.25 kg w/pedals, cages, sensors, Wahoo mount
Gravel
Velobuild GF-002 Force AXS 7.5 kg, ride-ready 7.775 kg w/200 ml Stan‘s, pedals, cages, sensors, Wahoo/Cateye mounts
