Hi, everybody, I cant find the torque specs in the campagnolo PDFs of this screw:
Does anyone know the recommended torque in Newton meters (NM)?
thanks!
Torque specs - campagnolo cage - (chorus/record) 11v
If there's no specific torque then it would depend on the bolt size. I think that might be a 6mm allen key? Maybe a 5. Personally I'd go with what used to be the case before carbon fibre and precise torque became a thing and just do it up tight without trying to break it and use a bit blue threadlocker on it. I doubt it will ever come undone if you do that.
thanks!, maybe the threadlocker will do the trick!, the allen key is a 5, the case is not carbon fiber, its plastic, the carbon fiber is the outside part.c60rider wrote: ↑Sun Jun 04, 2023 10:29 pmIf there's no specific torque then it would depend on the bolt size. I think that might be a 6mm allen key? Maybe a 5. Personally I'd go with what used to be the case before carbon fibre and precise torque became a thing and just do it up tight without trying to break it and use a bit blue threadlocker on it. I doubt it will ever come undone if you do that.
thanks!
