Sram red crank in R8070 groupset possible?
extrusionedwin
by extrusionedwin
hello eveyone,
any good experiences using Sram red crank 46/33 in R8070 groupset?
I''m thinking to replace the actual R8000 crankset 50/34 to sram red dub crank 46/33, it is possible and any issues?
the reason the new sram red dub are very ligth just 577gr, this is very awesome to put in shimano groupset.
the dura ace still heavy over 686 gr and the ultegra R8000 still 711gr.
So if yes, It will be great to reduce the bike weigth 100gr less.
tks
Ritxis
by Ritxis
On my bikes I have Sram Red Exogram cranks (1 BB30, 1 GXP) 48/33 (Miche chainrings) DA mechanical 11 and Ultegra 12 Di2 ...... perfect working order
treyxt
by treyxt
Are you referring to sram red axs crankset or 11 speed red crankset? The 12-speed crank/chainrings are def not compatible. The 11sp stuff should all be swappable between shimano/sram though AFAIK.
Specialized Tarmac SL7 10r 61cm (Raw Black Carbon) / r9170 Dura-Ace Di2 11sp / Lightbicycle AR46
Cannondale SuperSlice Hi-Mod 58cm (From EF) / r8050 Ultegra Di2 11sp / AeroCoach Ascalon Carbon / AeroCoach AEOX Zephyr
markdjr
by markdjr
Do you need a power meter? I am using Red cranks w/ Quarq 4 bolt PM Spider and Shimano rings.
