How to remove campagnolo weird circlip?
ctrip
by ctrip
Hi everybody!, I have a very weird circlip on my campagnolo chorus 11v, and dont know how to remove it, its not a classic circlip, here is the picture:
Anybody knows this kind of circlip?
Thanks a lot!!
AJS914
by AJS914
It's not supposed to normally come off. What are you trying to fix?
ctrip
by ctrip
AJS914 wrote:
Tue May 30, 2023 8:14 pm
Change the internal spring, normally in others deraillereurs they have traditional circlips, you can remove them with a screwdriver, but this kind, never see one of those!
ctrip
by ctrip
nothing? nobody knows how to remove that circlip? its campagnolo specific?
joeyb1000
by joeyb1000
I've done it. It's just not easy because it wasn't supposed to be done. There is nothing special to do. The outer clip needs to come off first. Then the other one is easy.
Two tips:
mount a Torx wrench in a vice, and mount the derailleur on top of it.
That clip is going to go flying. So work in a clean area, or put a rag, tape or plastic wrap over it.
I did it because my hanger was out of spec, and I added another hole to lower the spring tension.
ctrip
by ctrip
thanks, thats exactly what I need to do!!!
But how do you remove it, by using a flathead screwdriver to pry it off? ( on the image in the yellow part)
joeyb1000
by joeyb1000
I don't remember. I think I got the corner chisel on the first one and pushed it off. That's probably why it went flying. The second one was easy.
Get them back on was not hard. The first one pushed on. Then the second went on with a pair of plyers.
Just out of curiosity, why are you taking it off?
ctrip
by ctrip
well, I want to try first if I can make a new hole, to give a little bit more tension, I bought the bike second hand, and maybe the previous owner stored for years in a big cog, so the spring had in tension for a long period of time. It happens in my old bike with a 105, and fixed drilling a little hole next to the original, to put more tension on the spring.
If I cant do it, then the other choice is buy the parts to campagnolo (spring + busher)
joeyb1000
by joeyb1000
viewtopic.php?f=3&t=140379&p=1247891#p1247891
Go down to the 15th post in this thread. The photos may help.
ctrip
by ctrip
joeyb1000 wrote:
Fri Jun 09, 2023 1:56 am
thanks!!!
