Is this ok? Help please
Trdiata
by Trdiata
I changed front shifting cable with new one and came like this.
Its a little bit split
It is shifting perfecty
I am just afraid it will snap or so
Is it ok or i do it again with new cable
Bobbyc123
by Bobbyc123
it will be fine. your rear shifter cable will snap before this one.
If you notice it fray any more, change it.
Trdiata
by Trdiata
Cable is fried after it is bolted so damages after nut
Probably will be ok :)
I also changed rear cable and its perfect
robbosmans
by robbosmans
The cable needs to be under the tension bolt
Trdiata
by Trdiata
It is under the tension bolt!!!
And turned anticlockwise
Trdiata
by Trdiata
Or what bolt?dont get it. It is under and anticlockwise left turn
MikeD
by MikeD
It looks OK, but the cable tightening screw is all the way in. Hopefully you also have an inline cable adjuster.
Trdiata
by Trdiata
Inline cable asjuster?what is that?any pictures?
MikeD
by MikeD
Trdiata wrote:
Tue May 30, 2023 9:12 pm
https://www.jensonusa.com/Jagwire-Inlin ... rs-en.aspx
Edopizzo
by Edopizzo
MikeD wrote:
Tue May 30, 2023 8:39 pm
There is no need for an inline cable adjuster with these derailleurs
