Going to the alps.
ultimobici
by ultimobici
BenCousins wrote:
CasualRider wrote:
Fri May 19, 2023 6:51 pm
What is your W/kg? if you're above 4.2-4.5W/kg 52/36 - 11/30 is more than enought. if it's below 4w/kg than I would ty to go with easier gear.
Shouldn't that be 'what cadence are you comfortable in at whatever watts/kilo you'll be riding?' Then you do the math and figure out the gears. I'm comfortable in a cadence of 60 at threshold.
Absolutely. Two people with identical numbers may be comfortable at wildly different cadences and consequently favour different gearing.
FlatlandClimber
by FlatlandClimber
Just choose the lighter gearing. Don't listen to "if your FTP is above XY, you'll be fine with ..."
Yes, a high FTP rider will be able to grind it out, but why would your put yourself through that, if you could just have another cog?
"Narrow gearing" will be nearly irrelevant on climbs this steep, and not having sufficient gearing will put you into a power or cadence, that may really hurt your performance for such a long event.
Get over the ego, and get low gearing.
Cervelo P5 Disc (2021) 9.1kg
S-Works SL8 (2023) 6.3kg
okx
by okx
+1 for low gearing.
having lower gearing - won't hurt, not having - may hurt.
BenCousins
by BenCousins
Is this about comfort (completing the event) or performance (getting the best time)? Because being under geared can hurt, if it slows you down. If you default to a certain cadence when fatigued, then having a lower gear may drop you into a lower power output and get you a slower time.
I think it's important for people to understand/learn where they default cadence-wise on long climbs when fatigued.
Mindflash
by Mindflash
Depends on your FTP. Above 4W/kg should be more than fine. Below, better switch to 34/30 or 36/34
BenCousins
by BenCousins
Mindflash wrote:
Sun May 28, 2023 12:05 pm
You are assuming what cadence he's comfortable with, and you don't have that info. I'm below 4 and climb on 36/29.
polpy
by polpy
And i am above 4 and most of the time in 34/30.
BenCousins
by BenCousins
polpy wrote:
Sun May 28, 2023 5:28 pm
Indeed. Which tells us it's personal.
polpy
by polpy
Exactly, its super personal and depends on so many things.
