Racework Carbon Cranks
mathemagician
by mathemagician
Think I saw Tracevelo review them on YouTube, but don't know if it was paid promotion. From what I saw, Shimano style crank / spindle interface, SRAM style chainring fixing, Rotor looks. No idea on performance though.
Sent from my CPH2207 using Tapatalk
tiddytoddy
by tiddytoddy
Yeah as masthemagician said Tracevelo did a video on these. He states that he bought them with his own money, but does link to an affiliat aliexpress store at the end.
Overall he seemed pretty happy with them but have a look for yourself: https://www.youtube.com/watch?v=J2NmySF6hh4&t=752s
rhs2z
by rhs2z
I have BB86 fitted with DA cranks. I periodically check in on this: are there any magical new crank options for Bb86 that could lower the weight without while maintaining stiffness?
This Racework crank set has a 24mm aluminum axle. I assume this will ruin either the stiffness of durability of the crank (or else other companies would use 24mm aluminum)? Does that seem right?
Nickldn
by Nickldn
Are there any good 12s crank alternatives to DA? Lighter weight without compromising shifting performance. Would prefer something carbon but not SRAM or Campy. Can't afford THM.
Giant Propel Advanced SL Red Etap 11s Easton EC90 wheels CeramicSpeed BB Zipp SL70 bars 6.5kg
Vitus ZX1 CRS Campy Chorus 12s Bora WTO 45 disk brake wheels Zipp SL70 bars 7.5kg
SL8 build with Craft CS5060 Wheels in progress
Kayrehn
by Kayrehn
Rotor Aldhu carbon? Fairwheelbikes just released their most recent cranks testing results and 4he Aldhu seems like a fine choice.
X5SAE
by X5SAE
Kayrehn wrote:
Wed May 17, 2023 1:46 am
Aren't they 30 mm only? Too small bearing size for a 41 mm bb shell...
Road
Cube Agree C:62 SLT 2021 (frame+fork) DA 9270 6.9x kg - ride-ready 7.25 kg w/pedals, cages, sensors, Wahoo mount
Gravel
Velobuild GF-002 Force AXS 7.5 kg, ride-ready 7.775 kg w/200 ml Stan‘s, pedals, cages, sensors, Wahoo/Cateye mounts
BigBoyND
by BigBoyND
X5SAE wrote:
Wed May 17, 2023 4:53 am
No, there's a 24mm axle option. But it weighs a bit more since it has to be steel.
X5SAE
by X5SAE
BigBoyND wrote:
Wed May 17, 2023 5:28 am
Ah nice, thanks. :thumbup:
Would be nice if there was an option for 24 mm titanium axle like with SRM.
Road
Gravel
alanyu
by alanyu
No, ALDHU carbon only has 30 mm choice.
BigBoyND
by BigBoyND
Damm, really? The interface looks the same. Why is that axle not compatible with the carbon arms?
robbosmans
by robbosmans
Rotor crankarms are specific to their spindle. They give the illusion you can choose either axle but you can’t.
rhs2z
by rhs2z
From a materials standpoint, are there any downsides to a 24mm titanium spindle like the one from SRM? (Besides it costing a fortune, at least in the SRM case.)
Bazzman1968
by Bazzman1968
Does it bother anyone to mix the cranksets from different groups, Campy/SRAM/Shimano? Thanks Baz
taladjidi
by taladjidi
Hi all, I took the bait and bought one of these in order to swap my PM to a Sigeyi axo. The non-drive side crank arm cracked as I was tightening the two pinch bolts. Since there was no torque info I started at 8 N.m (I took for reference that Shimano cranks have a 12 to 14 N.m rating). I stopped as soon as I heard suspicious noises but the damage was done ... Guesstimating, I'd say that I was around 5 N.m given how easy the bolts turned.
I'll upload some pictures tonight. I'll try to contact the seller to get a replacement arm, if this fails I'll try to find a 3 bolt SRAM Red GXP crankset.
I would really be interested if someone has any experience with it and what torque they used, else I guess I'll just be the Guinea pig for the community :D
