Kogel Kolossos vs CeramicSpeed OSPW
- wheelsONfire
A question regarding the ospw systems, Kogel Kolossos and CeramicSpeed OSPW.
Have anyone tested or perhaps owned both systems?
Kogel claims it's stiffer than competitors which i guess is a real advantage!?
(Less lateral side play)
Part from the so called gains (miniscule), are there any negative side effects like hesitant shifting, overly fast pulley wheel wear, increased noise?
Bikes:
Open *UP* (2016.04.14)
I run a kolossos on my dura ace drivetrain. I'm not in a position to comment with any authority on drivetrain efficiency and watts but I tell you with absolute certainty that it is MUCH quieter than the stock DA cage/pulleys, and the shifting is flawless. Most noise is generated by things rubbing together, so less noise seems like it SHOULD be more efficient, right?
I scored mine as an openbox for very cheap. I would do it again in an instant based on my experience so far.
- wheelsONfire
Thanks!pushpush wrote: ↑Mon May 15, 2023 4:39 amI run a kolossos on my dura ace drivetrain. I'm not in a position to comment with any authority on drivetrain efficiency and watts but I tell you with absolute certainty that it is MUCH quieter than the stock DA cage/pulleys, and the shifting is flawless. Most noise is generated by things rubbing together, so less noise seems like it SHOULD be more efficient, right?
Yeah, the price is obscene. Do you see any benefit at all if you are totally honest?
I tried to get info if the Kogel bearing races are coated/ hardened or not, but no reply.
I think i will ask again.
EDIT: Kogel have hardened races and CS have two versions. Neither coated or hardened (cheaper) and one with coated bearing races (cost more).
Bikes:
Mine is quiet as well. On my other bikes, I used the Kogel oversized pulleys, 12/14T and like that combo. I didn’t have to use a longer chain and fills out the cage much better. Also, the 14T clears the 12-speed nub on the cage so no need to get a new cage.pushpush wrote:I run a kolossos on my dura ace drivetrain. I'm not in a position to comment with any authority on drivetrain efficiency and watts but I tell you with absolute certainty that it is MUCH quieter than the stock DA cage/pulleys, and the shifting is flawless. Most noise is generated by things rubbing together, so less noise seems like it SHOULD be more efficient, right?
- Factor Ostro VAM Disc
- Factor LS Disc
- Specialized Aethos Disc
- Sturdy Ti Allroad Disc
- Guru Praemio R Disc
- Factor LS Disc
Mine is good as well. Runs relative quiet on at R9200 drivetrain, quieter than my R9100 with Ceramicspeed OSPW (coated). I can give you more experience, when I build up my other bike with a R9200 DA group. There will be no OSPW, perhaps in future. Then I can give you a better response, but for now everything looks fine and I like the look. Gain 35g compared to the Shimano cage.
- wheelsONfire
Oh yes please doErwin wrote: ↑Wed May 17, 2023 7:16 amMine is good as well. Runs relative quiet on at R9200 drivetrain, quieter than my R9100 with Ceramicspeed OSPW (coated). I can give you more experience, when I build up my other bike with a R9200 DA group. There will be no OSPW, perhaps in future. Then I can give you a better response, but for now everything looks fine and I like the look. Gain 35g compared to the Shimano cage.
Bikes:
What kind of bike is it going on?
i was looking at one and decided against it.
I can't remember which video it was from, but it was around Kogel being more suited to a casual user with ceramic speed needing alot of upkeep to stay running well.
Ultimately i decided against one because i think they give off alpha male energy
Given that oversized pulley wheels have been proven time and time again to be useless watts-wise (in any study that was not payed by ceramicspeed), the idea that thinking there is gain between two marginally different OSPW is very mind boggling to me. And don't take me wrong, I love to spend absurd amount of money on bike, but this one is just in a ridiculous league of its own
#RETIRED# Lynskey “the Do-it-all Helix” :https://tinyurl.com/bdmb5y24
But it looks like you spent a ton of money on the bike. Bling, amirite?Yoln wrote: ↑Wed May 17, 2023 5:15 pmGiven that oversized pulley wheels have been proven time and time again to be useless watts-wise (in any study that was not payed by ceramicspeed), the idea that thinking there is gain between two marginally different OSPW is very mind boggling to me. And don't take me wrong, I love to spend absurd amount of money on bike, but this one is just in a ridiculous league of its own
To get rid of the noise from stock pulley wheels, I did replace the stock pulley wheels with ones from Cbear, which are bigger and continue to spin like crazy after 20,000+ km.
realistically, are people buying it for any practical reason?Yoln wrote: ↑Wed May 17, 2023 5:15 pmGiven that oversized pulley wheels have been proven time and time again to be useless watts-wise (in any study that was not payed by ceramicspeed), the idea that thinking there is gain between two marginally different OSPW is very mind boggling to me. And don't take me wrong, I love to spend absurd amount of money on bike, but this one is just in a ridiculous league of its own
It's a look. which is totally fine.
OP seems pretty serious about it...
Bobbyc123 wrote: ↑Wed May 17, 2023 7:29 pmrealistically, are people buying it for any practical reason?Yoln wrote: ↑Wed May 17, 2023 5:15 pmGiven that oversized pulley wheels have been proven time and time again to be useless watts-wise (in any study that was not payed by ceramicspeed), the idea that thinking there is gain between two marginally different OSPW is very mind boggling to me. And don't take me wrong, I love to spend absurd amount of money on bike, but this one is just in a ridiculous league of its own
- wheelsONfire
Yeah, i totally admit one thing. It's like 95% curiousity. I remember the first of these systems. It came from Germany. Sadly i don't remember what brand name it was.
I also wouldn't consider the new aero cover/ shield versions. It kind of hides the beauti. What totally makes no sense is the price of the upgrade, which is close to what a new RD cost.
Bikes:
The price is the point. It is a sticker that lets other people know how much you spent. It's functionally and aesthetically equivalent to the fancy logo on an otherwise cheap and ordinary t-shirt.wheelsONfire wrote: ↑Thu May 18, 2023 8:47 amWhat totally makes no sense is the price of the upgrade, which is close to what a new RD cost.
- wheelsONfire
Well, in that case i would be totally wrong person. Usually i only spend money on things i do believe in.jih wrote: ↑Thu May 18, 2023 8:52 amThe price is the point. It is a sticker that lets other people know how much you spent. It's functionally and aesthetically equivalent to the fancy logo on an otherwise cheap and ordinary t-shirt.wheelsONfire wrote: ↑Thu May 18, 2023 8:47 amWhat totally makes no sense is the price of the upgrade, which is close to what a new RD cost.
Most chronical OCD i have would include saddles and handlebar/+ stem.
Both bar and saddle i have searched for possibility to design my own. Sadly i don't handle CAD, which i must send.
Saddle would be Pro Aerofuel with total flat rear end. No tail up (it is in the shell).
Or longer rear end. I think the rear is far to short on saddles. Especially since they more or less angle upwards.
This hinder my need to stretch my back. I've been informed a new Pro Aerofuel was due januari, later postponed to April.
Now there are no signs of this at all. It was from Shimano this info came....
Bikes:
