24mm power meter
spartacus
by spartacus
https://www.bike24.com/p2392625.html?sku=1360865
I found a power pack with aldhu arms and oval rings for a similar price from Germany so maybe look around.
Aeo
by Aeo
My setup:
SRAM RED GXP cranks, Sigeyi power meter, in Giant TCR with Shimano-style bottom bracket
  • Aluminium spacer from Acros GXP Adapter, ground down a little bit because it was too wide.
    Now a little bit under 12mm.
    Black spacers are Wheels Mfg crank spindle spacers, one 24mm x 1mm and one 24mm x 0.5mm
    White translucent spacers are from the Acros set, nominally 0.4mm but measure around 0.33mm
Obviously, your amount of spacers will vary, find a setup with no play when crank is tight and you will not need wave washers.
Giant TCR Adv Pro Disc '17 · BH Lynx Race Evo '19 · Seraph GR029 '21 · Canyon Inflite AL '14
scottydonald
by scottydonald
Aeo wrote:
Sat May 20, 2023 12:10 pm
My setup:
Looks good!
After a week of thinking and reading I am now sitting between three choices:
Favero Assioma pedals
Or
Quarq Dzero, d1 arms, carbon ti rings and a new ceramics speed bracket
Or
Stages 9200 LR crankset.
Any more opinions?
scottydonald
by scottydonald
I just ordered another set of Assiomas.
All the options and this was the cheapest but most importantly didnt mean loosing my good bike for a time.....
Now just need to a find a 54t 9200 chaintring and see how it works with a 36!
rawjunk
by rawjunk
My setup:
Have you had any issues with that Acros GXP Adapter?
Aeo
by Aeo
No problems for 2 years
iamraymond
by iamraymond
Aeo wrote:
Sun Mar 10, 2024 2:24 pm
What bottom bracket are you using? Are you using the standard Shimano Ultegra or Dura Ace?
I'm currently trying a SRAM GXP BB with the SRAM RED AXS GXP cranks on my BMC SLR01. However the BB86 bottom bracket shell in my frame is grossly undersized (40.80mm instead of 40.98mm) and after pressing in the metal SRAM GXP bottom bracket the bearings don't spin so freely. The Shimano BB with their plastic construction grants enough tolerance that it works fine with 24mm cranks.
I'm thinking that I should try your suggestion with the ACROS GXP to 24mm adapter using the Shimano Bottom Bracket (either Ultegra or DA).
Aeo
by Aeo
Using a first gen Hambini BB86
If your shell is undersized but round, you could consider the flap wheel method to widen it just a little bit.
If you can get the Acros set for cheap enough, go ahead and give it a try
Spinnekop
by Spinnekop
Had the Asioma Shi pedals. Bearings went. Local agents did not have stock. Took months. I gave up.
Got the P2M and have been without issues since.
"In my experience, there is only one motivation, and that is DESIRE.
No reason or principle contain it or stand against it........"
Karvalo
by Karvalo
Nickldn wrote:
Fri May 12, 2023 11:06 pm
Even Shimano who bought Pioneer then decided to stop investing, because they saw no real future in the market.
I don't think there was ever an indication that Shimano wanted to sell Pioneer branded PMs given that they already did and still do sell their own crank based PMs. They just got a good deal on the IP. At the time I think it was more the web based training ecosystem they wanted to get hold of.
iamraymond
by iamraymond
Aeo wrote:
Tue Mar 19, 2024 1:40 pm
Alright thanks for the input.
Regarding the flap wheel method, I couldn't find one which is a good fit for the 41mm. I found 40mm wheels (too small) and 50mm (too big).
BenCousins
by BenCousins
Nickldn wrote:
Sun May 14, 2023 5:39 pm
Cannoli wrote:
Sat May 13, 2023 12:54 am
Seems like the spider based power meter is now largely dead. PM pedals have replaced it as the go to.
Huh? This is a personal opinion and not based in reality.
SRM makes a great power meter and can accommodate 24mm cranks. You can get a good deal on their PM7, or build out a killer PM9 that can be upgraded as you upgrade bikes.
It's an opinion based on the current market in general and UK prices in particular.
I googled the price of SRM power meters and nearly fell out of my chair! A Campy compatible PM and crank is £2,568 from TrainSharp cycling:
https://www.trainsharpcycling.co.uk/pro ... ag_organic
To me that's 1%-er money, not to mention about 5 times the price of a single sided pedal PM. I can't see the value.
Other non-campy SRM stuff with crank doesn't seem to be that much cheaper either. To me it's absolutely ludicrous to suggest that represents a healthy and competitive market compared to Assioma, or even Garmin power pedals (unless you're a 1%-er of course and care about price).
SRAM still makes QUARQ pms and they are better value (widespread distribution too), but they are SRAM only.
Sygeyi, yes their products are well priced, but not easy to get hold of in the UK.
So to me, no this is not a healthy market.
Whatever you do, don't look at the prices of SRM when they were the only option, and adjust for inflation. You'll consider the entire history of commercial power meters 'not a healthy market'
EugeneC
by EugeneC
Buy SRM second hand. It is hands-down the best pm out there. And the best thing about SRM is, that every part inside the application is repairable and replaceable. Everything can be taken apart and fixed. It's also possible to replace the chainset. They alse calibrate them. Once you've tried SRM it's hard to settle for less.
I've seen lots of them second hand going at around 500 euros.
Honestly I don't know who pays 1800-2500 euros for a new SRM. I've never met somehone who did that. Everyone I know buys them second hand.
Edopizzo
by Edopizzo
Get the Magene PES for 299 shipped
Whipit
by Whipit
Edopizzo wrote:
Fri Mar 22, 2024 11:15 am
Do you have one? Have you done an accuracy comparision? Price is definitely good!
