-17 stem with internal routing
j_gantzer
by j_gantzer
Any stems available in 110 x -17 with ACR / DCR style routing besides the Deda Vinci?
I'm looking for something lighter & with a more classic look. I'd also consider a one piece bar/stem
Thanks, JG
ViperFFM
by ViperFFM
subscribed because im looking for an alternative as well
carbonLORD wrote:
Fri Mar 12, 2021 12:23 am
I'm a CAT 3 Masters racer, not a dentist.
LouisN
by LouisN
I've already been looking without success.... :?
Hope the offers from third party brands will come out soon...
Louis :)
Yoln
by Yoln
Wilier Stemma carbon (not the stemma S which is aluminum) is -17, but it's insanely priced, you'd be lucky to find it below $600...
I've been looking a lot with no success, and eventually settled with a -13...
#RETIRED# Lynskey “the Do-it-all Helix” 🧬:https://tinyurl.com/bdmb5y24
ViperFFM
by ViperFFM
Yoln wrote:
Thu Mar 30, 2023 11:29 pm
Which one?
j_gantzer
by j_gantzer
This is the best option I have found so far- https://www.yoeleobike.com/collections/ ... n-stem-st1
"Only" -10*, but the stack height is a short 30mm.
ViperFFM
by ViperFFM
Damn; I would have tried that if they'd offer 130mm
BigBoyND
by BigBoyND
If you are considering one-piece, some brands have pro-spec bars that are -17deg. Side benefit is they are normally narrower for the stem length.
j_gantzer
by j_gantzer
BigBoyND wrote:
Wed Apr 26, 2023 7:22 am
Examples?
BigBoyND
by BigBoyND
Trek is an easy example. If you know someone working there, you may be able to get your hands on a set.
But if you check out pro tour team bikes you'll find other long/low pro-spec bars.
ricerocket
by ricerocket
Is this still a hole in the market?
Does anyone know if you have to run the spacer w/ the Vinci stem?
X5SAE
by X5SAE
ricerocket wrote:
Sat Sep 23, 2023 3:42 pm
Yes, you'd have to run the dustcover plus the stem transition spacer. I would guess those together to be between 15 and 20 mm high.
Road
Cube Agree C:62 SLT 2021 (frame+fork) DA 9270 6.9x kg - ride-ready 7.25 kg w/pedals, cages, sensors, Wahoo mount
Gravel
Velobuild GF-002 Force AXS 7.5 kg, ride-ready 7.775 kg w/200 ml Stan‘s, pedals, cages, sensors, Wahoo/Cateye mounts
ricerocket
by ricerocket
So I acquired this Deda Vinci stem, unfortunately the bar clamping width is too much for the bars I plan on running.
I found another option from Profile Design newly released this year. It's designed for tri bikes (and has a hydration system mount which is the dicknose on the front), but it's still lighter than the Deda, and allows for steerer mounted Di2. Only downside is it's only available in 80mm and 105mm so far. I'll see how this plays out.
https://profile-design.com/collections/ ... 0758964287
