Chain length 2019 Emonda sl disc
Daviesc
by Daviesc
Hi after some help with correct chain length.
I have a 54cm Emonda Sl6 disc (2019 Previous model).
I'm having issues with chain drop/suck when changing from 50 to 34t on my front crankset.
I have an 11-32 rear casette and in the middle of the cassette when changing I drop the chain (damaged frame already).
To avoid any more damage I am trying to find the cause. One possibility is incorrect chain length causing wrong chain tension.
Does anyone know how many links I should have for a 50/34 crankset and an 11-32 casette ulegra 8000 groupset?
Thanks
Karvalo
by Karvalo
Chain drop and chain suck are two very different things, and it's unlikely that chain length would be causing either of them.
ultimobici
by ultimobici
Is the bike still set up as stock? If so, it will have an Ultegra SS rear mech which is rated to 30T max. Looks like the Emonda SL6 didn't come with a long cage mech until this year when it was equipped with 105 Di2.
That might be the source of the issues.
DaveS
by DaveS
Use the chain length formula at parktool.com, if you know the chain stay length. A 410mm stay length with needs 54 inches of chain to wrap the 50/32.
Daviesc
by Daviesc
I swapped out the rear derailleur for a long cage one.
Any ideas what could be causing the shifting issue mid cassette?
I'll try the parktool calculator to rule out chain length.
Thanks
ultimobici
by ultimobici
Have you checked the hanger alignment? When did the issue start? Was it immediately after the change of cassette?
