Hello everyboy,
In 2018, I bought a Trek Domane equipped with a (pre DUB) Quarq DZero power meter like on this picture :
Few days ago, the Quarq spider battery compartment got destroyed
So, I need to replace the (Pre DUB) Quarq DZero spider .....
Involved parts are :
Bottom bracket: BB90 GXP ---> I keep that (no choice)
Crankarms : SRAM RED eTap GXP - 172.5mm - Exogram 8-bolt Interface ---> I would like to keep those
Power meter spider : Quarq DZero "pre DUB" 110 BCD - Hidden bolt ---> I need to replace that (Quarq battery compartment snatched out)
Chainrings : SRAM 110 BCD 50/34 Teeth - 11 Speeds ---> I would like to keep that
After having browsed on the net, I understand the only option is to buy a SRAM Quarq Power Meter DZero DUB AXS Spider | BCD 110 mm
https://r2-bike.com/SRAM-Quarq-Power-Me ... BCD-110-mm
I read that the use of this 2022 Quarq Spider is possible in lieu of a pre DUB Quarq spider but it would introduce some chainring offset .....
Shoud you have face similar situation, what is your experience ?
Thank in advance
Pre DUB Quarq DZero Spider replacement
It's really not enough to matter.
You can optionally try a Sigeyi, Xcadey or Magene spider-based power meter as well.
Ok, good to know ! I am just curious though as to why they call it DUB Quarq spider .... Thank you anyway.TobinHatesYou wrote: ↑Sat Jan 28, 2023 3:53 am
As far as replacing the battery compartment itself, I need to spend some time on this option. You are right : just one small screw ! that would be great !
