Elilee Blize XXE 680g Disc Frame 330g Fork
Interesting-- and good-looking frameset. The geometry is very differentiated, with two fork-rakes and -chainstay-length (...and obviously even two differing fork-length...). If i needed a frame, i would highly consider this one.
I removed the front derailleur hanger and the chainstay protection shield (real carbon BTW). There was a matte clear on the frame, so I sanded it down completely. We're now at 756g. 43g more than my sanded size 54 S-Works SL7. Again, this is the standard Blize, not the lighter XXE.
Oh wow only ~13g saved after sanding the frame?
I sanded 6 different frames to bare carbon in the last 6 months. This one was the easiest by a country mile. And I didn't do it for the weight saving primarily but rather to have a uniform surface on which paint can be added.
Stickers were over clearcoat.
Blize has now been officially launched, here is the marketing material including rigidity and aero data
Here's what I read from The charts.
The sl7 is not as bilaterally stiff on rear triangle. The bb area on sl7 isn't as stiff because they changed to bsa instead of press fit. The headset on the sl7 way stiffer than the other frames. They are very happy to see the top xxe vs the sl7 stiffness v weight ratios are so close. They give props to the pinerello aero and I'd say they sound proud their frame is more aero than the sl7. I think they refer to the blize as a climber style frame with aero. They explain the headtube angles and heights. Shorter frames needed more fork angle to prevent toe overlap, improve handling, and higher tube height than normal to stiffen the front. While the largest frame have shorter than normal headtube to keep the stiffness of the front triangle. The choice in geometry is ment for a race position.
The top couple of pics talk about how much time they worked on this bike 3 years. The dedication to precise workmanship in all their products.
Sorry for my ignorance, but does "officially launched" mean it will be easier to order one? ...or will I still have to go through instagram? I tried the google machine and nothing comes up yet.StiffWeenies wrote: ↑Tue Mar 07, 2023 3:42 pmBlize has now been officially launched, here is the marketing material including rigidity and aero data
Sorry you're right. Was a lot to interpret and messed this up and forgot what the chart said as I wrote it.
aero chart shows some generic frame in yellow, blize, then sl7 as best. they never put the pinerello on the chart just mentioned it. The test was done at 40km/h
I believe the "G" brand frame refers to Giant TCR
My bad for being unclear. Chinese dealers have already started pre-selling the frame for quite some time now, so I used 'officially launched' to denote that Elilee is now posting about it on their social media in a formal capacity with testing data. I don't think they have a proper dealer network outside of China atm so it's still best to talk through Insta or WeChat.
What did you coat the frame with after sanding?
Cool, just sanding a frame at the moment and undecided what to use.
Usually its spraymax 2k, but another forum user gave me a recipe of something to try. Always interested in trying something new.
The frames looks great.
