Hexsense wrote: ↑Mon Dec 12, 2022 10:45 pm
Nickldn wrote: ↑Mon Dec 12, 2022 10:06 pm
cerro wrote: ↑Mon Dec 12, 2022 8:44 pm
tmrace wrote: ↑Mon Dec 12, 2022 6:56 am
I'm hoping that SRAM will shift to use mineral oil like they did this year with their DB8 brakes.
I heard that there is a dealer presentation on the new group happening over the next couple weeks.
Maybe we can gather some more information when those presentations start.
So we can have leaking squeeling brakes like Shimano?
No thanks.
Not sure if I'm reading your message right, but it would be good to know how use of mineral oil contributes to Shimano's squeaky brakes, compared to DOT brake fluid used by SRAM. Is this really a thing?
Shimano leaky ceramic piston is a problem exclusive to Shimano. Not all piston do it. But the defective ones (which strangely not so rare) let mineral oil slowly weep through ceramic piston very very slowly. It'll contaminate the pad and disc if the bike is left no use for months (like storing bike for winter, to use it in spring/summer). It's more common on mtb where there are more smaller pistons per caliper vs fewer bigger piston road caliper.
Other mineral oil brakes such as Magura, Campagnolo, Formula, TRP, Hope don't have this issue. So I won't tie this issue to mineral oil either. It's Shimano issue, not mineral oil issue.
It's probably safe to say leaking pistons are an industry wide problem. Shimano is the biggest and so would have the highest number of cases, but I doubt any manufacturer is blameless.
I have had an issue with a Campagnolo caliper leaking fluid and contaminating brake pads. Sadly Campy's UK distributor refused to warranty the caliper and said it must have been a fitting issue, despite the bike being checked by a Campy service centre. I have new caliper on the bike now and it works perfectly.
The reason brakes are an emotive issue is because it really affects safety. If the bicycle industry was as regulated as the car and motorcycle industry we would have much more reliable brake calipers and fewer Micky Mouse pistons/seals.
As for SRAM, yes they are different, but as far as I know the only advantage of DOT brake fluid is that is has a higher boiling point than mineral oil. Great for a car, or motorcycle, but really not sure if it's any advantage to a bicycle braking system. The real issue with DOT brake fluid is that it's a great paint stripper. I'd be happy to see DOT go.
