Favero assioma duo in other pedal body mods
Hey All
I have noticed that the Assioma Shi is able to be placed in many bodies other than the recommended shimano pedals, what my question is if the regular pedal on the look keo style pedal if it were to be broken down to the shaft could it be installed on my look blade pedal with out too many issues (asides warranty)
Has any one done this mod and if so are there any images in the wild or how to links?
cheers
cheers
Forget about it
#RETIRED# Lynskey “the Do-it-all Helix” :https://tinyurl.com/bdmb5y24
The non-Shi Assioma share their spindle/body interface with a well-known subset of Xpedo pedals (Favero has partnered with Xpedo so that they wouldn't have to design their own Keo clone mechanism), and that spindle/body interface has absolutely nothing in common with what Look is using on their own pedals. I'm fact Look have more in common with how Shimano does that than with how Xpedo/Favero do it. Look and Shimano have a body that's completely closed on the outboard end, fixing the body laterally with an inverse nut wrapped around the inboard end of the spindle, whereas Favero/Xpedo fix with a tiny regular nut on the outboard end, hidden behind a screw-on cap. (This certainly doesn't imply that Shimano and look bodies are interchangible, but they use the same basic design principle)
In short: clear and definite no, there is zero similarity outside the body/cleat interface.
I think i mis wrote the question, the "non-shi" favero assiomas the ones that come in the look keo pedal, I was enquiring if that spindle could be removed an placed in a keo blade housing, that is if you are crazy enough to play with the setup, can that be done, but usr thanks for that explaination it was very precise
A Keo Blade compatible Assioma spindle would be incredible
Maybe you can first do a visual check on the assioma and keo blade axle by googling them?
The problem with Look is that they appear to use a different spindle for each of their pedal bodies
If we look at the aftermarket, J&L has several listings for their Ti spindles depending on the model. The DUO-Shis work with several Shimano pedal bodies but a spindle for the Keo Blade would probably just work for that model/generation alone.
I had older Look pedals for the last 2 or 3 decades, now on Favero Assioma.jenk wrote: ↑Mon Jul 18, 2022 5:43 amHey All
cheers
The only Look pedals I immediately ditched after buying ( all failed) are the blade system.
I honestly don't know why someone would want to change the original Assioma for a Look blade body ...
Louis
I would like to see if there is a mysterious way to attach a Look pedal body to an Asssioma spindle. The powermeter is spot on, the pedal body however sucks. A lot of float, and a carved out spot on the metal plate which is supposed to transfer hell lot of power to propel the bike. I don't like the Xpedo pedals but totally love the Favero's system (portability, easy to maintain, switch on the travel mode, etc.). So an option to upgrade to the Look pedal body would be incredible!
