Resolved / Identify BB and removal tool for Cervelo Aspero BBRIGHT for Shimano
req110
by req110
Can you help me find right tool to remove this bottom bracket?
It's on Cervelo Aspero 2021 (BBRIGHT) for Shimano cranks. Looks to be threaded fit.
Spec says JY-BB 24.
Resolved, I think it's 16 notches, 48.5mm outside
From design it looks like this? https://wheelsmfg.com/bbrighttm-outboar ... black.html
SW SL8 RTP 56cm @ 9270 / CLX II / CS OSPW / CEMA BB
S Epic 8 L @ XX T-Type / Berg Ratheberg 30 / Quarq / Fox Transfer SL 100mm / 3p
JayUK
by JayUK
Hi there,
Sorry to resurrect your old post, but did that tool fit your bottom bracket?
From what I've read the BB's were push fit, but it appears the newer Cervelos are using a threaded version of the BBright BB (eg yours)? Was it making a creaking sound, hence why you need to remove/place it?
What did you replace it with?
Karvalo
by Karvalo
Only the R5CX, Soloist and the MTBs use a threaded shell. However on all the other press fit BBRight bikes Cervelo has for several years tended to spec a thread together bottom bracket units (from BBB IIRC) except for the highest spec models with CeraminSpeed.
