GeaerGrimsrud
by GeaerGrimsrud on Thu Jul 28, 2022 1:35 am
spib wrote: ↑Wed Jul 27, 2022 11:16 pm
Maybe I'm getting into the weeds here, but I'm having a hard time with cervelo sizing- I currently ride a tarmac sl6 in a 56, with a 120mm -7 stem and 25mm of spacers. 58 seems nearly perfect slammed but with the 80mm reach bars (current is 70mm) I'm scared the reach will be too long especially with the new ultegra hoods (current is r7000). 56 is definitely the safer bet but it looks so damn ugly with a lot of spacers! Especially since it seems like the bar-stem spacers are gone for 2023. I'm 185.5cm, 88.5cm inseam for reference.
I had a similar situation for the 2022 model, being between a 54 and a 56. I wanted to avoid spacers, and the 54 would mean a severe saddle-to-bar drop and having to swap in a longer stem.
I solved it with a 56 and a 0 offset seatpost. The new bike comes with a 15 offset seatpost, BTW. The previous generation came with a 25, so if you move to a 0 it won't be as dramatic.
mrlobber
by mrlobber on Thu Jul 28, 2022 6:09 am
Are they really gone? That would be really unbelievable. Can't find right now, but I think I saw a Jumbo S5 pic with a 5mm spacer below the bars.
Andrew69
by Andrew69 on Thu Jul 28, 2022 6:29 am
mrlobber wrote: ↑Thu Jul 28, 2022 6:09 am
I saw a 2023 S5 this morning built up and waiting for its new owner to pick up this afternoon
Had 3 x 5mm spacers under the stem, so Im not sure where spib got that idea from
TobinHatesYou
by TobinHatesYou on Thu Jul 28, 2022 6:32 am
Andrew69 wrote: ↑Thu Jul 28, 2022 6:29 am
He perhaps meant the angled shims for the bar. The bar/stem combo now uses a sliding interface to adjust the bar angle.
Andrew69
by Andrew69 on Thu Jul 28, 2022 7:36 am
TobinHatesYou wrote: ↑Thu Jul 28, 2022 6:32 am
Thanks makes more sense
Edit: I dont think it was the new model....how can it be so soon?? Must have been the older model
FlatlandClimber
by FlatlandClimber on Thu Jul 28, 2022 7:41 am
Nejmann wrote: ↑Thu Jul 28, 2022 6:57 am
So is the max size 58 in the new S5? I'm a 61 in specialized or do i buy a more upright stem with spacers?
It's been like that since the last gen already.
I sold my 58 S5 to someone 6'4" and with seatpost extended to all but 1cm and 120mm stem, it fits him perfect.
Cervelo P5 Disc (2021) 9.1kg
S-Works SL8 (2023) 6.3kg
Karvalo
by Karvalo on Thu Jul 28, 2022 7:56 am
proffate wrote: ↑Thu Jul 28, 2022 12:17 am
Karvalo wrote: ↑Tue Jul 26, 2022 6:59 pm
proffate wrote: ↑Tue Jul 26, 2022 6:38 pm
mrlobber wrote: ↑Tue Jul 26, 2022 11:57 am
Also, I wonder what default stem lengths and bar widths does the bike come with depending on size.
this, also what is the angle of the stem? We need a calculator to determine cockpit sizing based on desired touch points.
It behaves as a normal 6 degree stem. You don't need any different calculator than you do for any other bike.
Because of the low stack height?
Because Cervelo did the calculations before releasing the last bike because they knew people would need to be able to compare the S5 to other bikes.
A Cervelo V stem with for instance 100mm -6 written on it behaves the same way as a conventional 100mm -6 stem would on the geometry chart of the bike.
headstart
by headstart on Thu Jul 28, 2022 2:01 pm
Andrew69 wrote:TobinHatesYou wrote: ↑Thu Jul 28, 2022 6:32 am
New models are already available and on shop floors in limited quantities.
Gx3
by Gx3 on Thu Jul 28, 2022 2:27 pm
Does anyone know what size stem and bars come standard on the size 56? I've seen in numerous articles where the sizes are dependent upon frame size, but can't find any specific details.
Gx3
by Gx3 on Thu Jul 28, 2022 3:42 pm
Yikes - I need a 120 stem and would prefer a 38 bar, so I guess I'll need to order those separately. At this point, I'm having a hard time finding any dealer that has access to a 56 frameset. If anyone has any leads on where a 56 in the black colorway can be sourced, please do share.
Gx3
by Gx3 on Thu Jul 28, 2022 6:06 pm
GeaerGrimsrud wrote: ↑Thu Jul 28, 2022 5:14 pm
Gx3 wrote: ↑Thu Jul 28, 2022 3:42 pm
Here's a complete bike:
https://www.seriouscycling.com/product/ ... -11385.htm
Thanks - will keep my eye on that site to see if/when they get any framesets
wheelsONfire
by wheelsONfire on Thu Jul 28, 2022 9:47 pm
The blue is a nice color, but the white i really don't like.
Bikes:
Open *UP* (2016.04.14)
