About Cervelo S5 2023
In an interview on the new turbulent reserve wheels they talked about the new s5 for a minute of two. Sounds like it's ready. I imagine that's part of the reason there's not more info on the new wheels, they were waiting to do presses releases on both at the same time.
I had thought the new s5 would drop at eurobike, but that didn't happen.
The whole team is on the new S5 frame, though, in all different sizes. It's just the latest trend, bikes are ridden way before available in the market due to logistics. Would love to know more though, they're winning everything on this S5
Link to video?cajer wrote: ↑Fri Jul 22, 2022 4:19 pmIn an interview on the new turbulent reserve wheels they talked about the new s5 for a minute of two. Sounds like it's ready. I imagine that's part of the reason there's not more info on the new wheels, they were waiting to do presses releases on both at the same time.
edit: found it
https://youtu.be/46pCtym5tP8
Interesting that they tested the S5 prototype with the wheels.
FM125, Size 56, 1000 g is what is written on that downtube, but I think that's the old frame design
That's the old frame. There's a podcast on cycling tips. But anyways as an engineer I don't really buy the whole turbulent air optimization. It's not new, has been done for a long time in other fields. But It'll generally make things more stable rather than much faster, and as someone who started off using a 70mm from wheel in 2013 I don't think it matters that much.justkeepedaling wrote: ↑Fri Jul 22, 2022 5:35 pmLink to video?cajer wrote: ↑Fri Jul 22, 2022 4:19 pmIn an interview on the new turbulent reserve wheels they talked about the new s5 for a minute of two. Sounds like it's ready. I imagine that's part of the reason there's not more info on the new wheels, they were waiting to do presses releases on both at the same time.
edit: found it
Also the air the front wheel sees is mostly clean expect when drafting and at that point wheel aero doesn't really matter much anymore. Plus the rear wheel is so hidden that rear wheel aero doesn't matter much either. Either way at the end of the day where aero matters most is when you're off the front and there, air is mostly clean.
What I would be interested in seeing is how the flows looking for the wheel looks during cyclic changes to yaw in the 1-2 degree range (from steering inputs) and optimizing around that.
Where their moped setup is likely to be more useful is in bike design to validate some cfd or wind tunnel data of flow behind the rider.
I'm an aero engineer. Yeah, agreed, the flow for the front wheel is mostly clean. But I think some turbulence input in the freestream is more accurate, especially at these lower Reynolds numbers (compared to cars and planes). I personally wouldn't expect it to change much in overall ranking of design, but perhaps in magnitude of drag. It could be useful for optimizing the overall system with the fork and headtube.cajer wrote: ↑Fri Jul 22, 2022 5:58 pmThat's the old frame. There's a podcast on cycling tips. But anyways as an engineer I don't really buy the whole turbulent air optimization. It's not new, has been done for a long time in other fields. But It'll generally make things more stable rather than much faster, and as someone who started off using a 70mm from wheel in 2013 I don't think it matters that much.justkeepedaling wrote: ↑Fri Jul 22, 2022 5:35 pmLink to video?cajer wrote: ↑Fri Jul 22, 2022 4:19 pmIn an interview on the new turbulent reserve wheels they talked about the new s5 for a minute of two. Sounds like it's ready. I imagine that's part of the reason there's not more info on the new wheels, they were waiting to do presses releases on both at the same time.
edit: found it
For me at my weight (and lack of handling skills), I get blown around even on my C24 wheels. So I could use all the help I can get in wheel stability.
I had an email chat with Phil a long time ago (like 2007) about fork position sensitivity with Bayonnet fork designs when Felt was using that and P3's weren't. Even had ideas of active fork geometry back then to shield the legs in variable wind conditions or in yaw
That's skill and confidence, not weight. I work with someone who's 4'11" and happily races an 80mm front in most conditions.justkeepedaling wrote: ↑Fri Jul 22, 2022 7:25 pmFor me at my weight (and lack of handling skills), I get blown around even on my C24 wheels. So I could use all the help I can get in wheel stability.
Shallow wheels also aren't necessarily that great in crosswinds. Sharp edge C24s have had no though whatsoever go into the handling effects of the rim shape. Someone at ENVE once wrote about it either in an interview or blog post - that deeper wheels release turbulent flow more smoothly and at a lower frequency than shallow. His point was that while a 7.8 or similar will have more ultimate side force than a 3.4, the 3.4 could still be a less confidence inspiring ride because it'll feel like it's hitting sharper and more frequent gusts.
I agree with fork/wheel/downtube/headtube interactions and optimizing around that. However it's quite different for each bike with some hugging the downtube while others having a gap between the downtube/wheel or down tube and fork legs and same with headtube. So what we might end up with is a new S5 (not this 2023 one which is stated to not use turblent desgin) around the Reserve wheels.justkeepedaling wrote: ↑Fri Jul 22, 2022 7:25 pmI'm an aero engineer. Yeah, agreed, the flow for the front wheel is mostly clean. But I think some turbulence input in the freestream is more accurate, especially at these lower Reynolds numbers (compared to cars and planes). I personally wouldn't expect it to change much in overall ranking of design, but perhaps in magnitude of drag. It could be useful for optimizing the overall system with the fork and headtube.cajer wrote: ↑Fri Jul 22, 2022 5:58 pmThat's the old frame. There's a podcast on cycling tips. But anyways as an engineer I don't really buy the whole turbulent air optimization. It's not new, has been done for a long time in other fields. But It'll generally make things more stable rather than much faster, and as someone who started off using a 70mm from wheel in 2013 I don't think it matters that much.justkeepedaling wrote: ↑Fri Jul 22, 2022 5:35 pmLink to video?cajer wrote: ↑Fri Jul 22, 2022 4:19 pmIn an interview on the new turbulent reserve wheels they talked about the new s5 for a minute of two. Sounds like it's ready. I imagine that's part of the reason there's not more info on the new wheels, they were waiting to do presses releases on both at the same time.
edit: found it
I also agree with the fact that some likely quite small turbulence input in the freestream is accurate (espically as yaw angles seen at small meaning generally low wind speeds), but am uncertain it will lead to more changes in wheel design to make them faster rather than more stable.
What ideas did you have around active fork geometry?
The new S5 has been announced officially, it's on the Cervelo website with Action Dynamic Video and the imprimatur of Wout, Mariane Vos, Laporte
Cannondale Supersixevo 4 (7.05 kg)
Retired: Chapter2, Tarmac SWorks SL6, Orbea, Dogma F8\F10, LOW, Wilier, Ridley Noah, Cervelo R3\R5\S2\Aspero, Time Fluidity, Lapierre Pulsium, Cyfac, Felt, Klein, Cannondale pre-CAAD aluminum
The press articles state that the potential damage to the head tube is not present anymore, so it looks like they've moved away from the internal fork turning limit stop. Have they indeed?
Also, another example of proprietary stuff not being carried forward - even though the stem and bars look almost similar to the outgoing version, the old stuff is apparently incompatible with the new fork.
Gran Fondo cycling reviewed it and apparently their stock bike is 7,50kg with Ultegra 8100 (no pedals, cages, mount). Considering it comes with 28c tires and wide and deep wheels, that is pretty good.
Lighter tires, a light aero wheelset (sub 1400g), a Darimo seatpost, lighter saddle and 9200 and your likely close to 7kg for a full build
Cervelo P5 Disc (2021) 9.1kg
S-Works SL8 (2023) 6.3kg
James bike @ Cyclingtips size L was 8.03kg Ultegra Di2 without pedals. I'd tend to believe this number more.FlatlandClimber wrote: ↑Tue Jul 26, 2022 11:06 amGran Fondo cycling reviewed it and apparently their stock bike is 7,50kg with Ultegra 8100 (no pedals, cages, mount).
Yeah, that's a lot more what I thought it would be...
Also, I wonder what default stem lengths and bar widths does the bike come with depending on size. Dare we hope that the default handlebar width C-C is 40cm or less?
