2022/2023 Canyon ULTIMATE
Thnx!
Doesn't really make me happy
What a silly system, you need to remove everything in case of a new bearing.
Yes you do (like almost all one-piece cockpits ).....do NOT remove the old hoses beforehand but use them to guide the new ones. Getting the hoses through this cockpit is an absolute nightmare ! Even with the Parktool INTERNAL CABLE ROUTING KIT......Daniel1975 wrote: ↑Tue May 02, 2023 7:30 pmThnx!
Canyon Aeroad CFR
Canyon Grail CF
Canyon Grail CF
im thinking to buy new canyon bike but i'm confused about geometry. Ultimata and aeroad have the same rech and stack but Ultimate has diffrent stack + w mm. Stack +w mm is measured with bars and ultimate has 681mm. Aeroad has 661mm so there is 20mm difference and here is my question how this is possible??? bouth bikes use the same cockpits CP0018. is this possible that ultimate use diffrent cockpit head spacers???
sorry for my english
No I'm talking about new ultimate and aeroad.
Check this out
https://zapodaj.net/plik-Sfxomwdl4F
https://zapodaj.net/plik-flbvts873p
CP15 and CP18 are both for new models. CP15 is the "pro" model that comes on some models like MVDP, and that one is lower.mw1978 wrote: ↑Tue Dec 19, 2023 6:21 pmNo I'm talking about new ultimate and aeroad.
Check this out
Looks like both of the ones you are looking at use the CP18, so one of those charts is wrong in the stack+/reach+.
Customer service should be able to tell you which of the two is correct.
