spdntrxi
by spdntrxi on Thu Feb 23, 2023 7:53 pm
joejack951 wrote: ↑Thu Feb 23, 2023 7:47 pm
robeambro wrote: ↑Thu Feb 23, 2023 11:21 am
I suppose Classified gives you an advantage in these situations (i.e. huge chainrings), since the 1:0.686 ratio gives him a virtual 20-tooth gap (virtual 62-42ish), which would be substantially more than any 2x setup could offer.
While a 20T gap sounds impressive, the ratio is really what matters. A 1:0.686 ratio works out to be exactly the same as what is offered by a 52/36 or 50/34 crankset.
exactly... I while I understand that.. the real bonus would be lower. For instance if I could get .6 on my gravel bike.. which would be 50/30 hell yes sign me up.
2024 BMC TeamMachine R
2018 BMC TImeMachine Road
2002 Moots Compact-SL
2023 Pivot E-Vault
AndreLM
by AndreLM on Thu Feb 23, 2023 7:55 pm
This thread got me thinking about Classified as well...
I am probably alone in this one, but I think combining a Classified hub with Rotor 1x13 RD (configured as 12 speed) would make a very light system, with good enough shifting - even in fully integrated bikes - and excellent braking performance.
It would definitely look a Frankenstein though
Sent from my Pixel 7 using Tapatalk
Stendhal
by Stendhal on Thu Feb 23, 2023 8:14 pm
With Adam Hansen's retirement, Campanaerts has taken over the mad bike scientist role on the Lotto team. Good for him, lots of respect.
Cannondale Supersixevo 4 (7.05 kg)
Retired: Chapter2, Tarmac SWorks SL6, Orbea, Dogma F8\F10, LOW, Wilier, Ridley Noah, Cervelo R3\R5\S2\Aspero, Time Fluidity, Lapierre Pulsium, Cyfac, Felt, Klein, Cannondale pre-CAAD aluminum
jayjay
by jayjay on Thu Feb 23, 2023 8:44 pm
AndreLM wrote: ↑Thu Feb 23, 2023 7:55 pm
I think you are still tied to the Classified cassettes
robeambro
by robeambro on Thu Feb 23, 2023 8:44 pm
I said that Classified would be ideal in "these situations", ie a pro rider fitting a monstrous chainring, so I'm not sure what's the point of mentioning 50/34 and 52/36 setups?
AndreLM
by AndreLM on Thu Feb 23, 2023 8:57 pm
jayjay wrote:AndreLM wrote: ↑Thu Feb 23, 2023 7:55 pm
Yep... But I doubt the spacing in the 12s cassette from Classified is too different from Rotor's (or Shimano, SRAM, Campy...).
The idea of using Rotor is just that it is probably the lightest RD + shifter combo (especially considering it has a clutch)
Miller
by Miller on Thu Feb 23, 2023 9:00 pm
jayjay wrote: ↑Thu Feb 23, 2023 8:44 pm
You are, because the Classified shifting internals occupy space that in a conventional wheel is taken up by the freehub. I think the Classified cassette must be quite conical.
jlok
by jlok on Fri Feb 24, 2023 10:59 am
If a FD can't shift 20T safely, then the 1x classfied hub makes sense when the pros want a 60T ring.
joejack951
by joejack951 on Mon Feb 27, 2023 4:11 pm
robeambro wrote: ↑Thu Feb 23, 2023 8:44 pm
My point in mentioning those more common setups is simply to point out that the relative change (which is what matters, not simply tooth count) between 62 and 42 isn't anything special. With a properly profiled front derailleur, Shimano, Campagnolo, Microshift, and eventually maybe even SRAM, could all pull it off. Perhaps your point was that no front derailleur currently exists for that chainring combo? You seemed more impressed by the 'virtual 20-tooth gap' in your comment, though.
joejack951
by joejack951 on Mon Feb 27, 2023 4:14 pm
spdntrxi wrote: ↑Thu Feb 23, 2023 7:53 pm
Bring back the 52/42/30 triple!
BigBoyND
by BigBoyND on Tue Feb 28, 2023 9:56 pm
joejack951 wrote: ↑Mon Feb 27, 2023 4:14 pm
If one of the three brands made this an option on their first or second tier group, I would buy it. Or a 50/30 if they can make it shift well!
joejack951
by joejack951 on Wed Mar 01, 2023 6:04 pm
BigBoyND wrote: ↑Tue Feb 28, 2023 9:56 pm
We all mourn the loss of this one:
...though it is a 52/39/30. I own two Stronglight carbon triples in 52/42/30. The biggest issue is finding front derailleurs that shift them cleanly.
wheelsONfire
by wheelsONfire on Sat Mar 04, 2023 5:14 pm
I wonder how the development will progress. In some ways i think about Srams crank which was supposed to incorporate FD shifting.
Which system is really the better of these two?
Is simplicity just more simple, or is it the best?
If so, i guess Classified has gain here, or?
Let's say you build a new bike around Classified with your own choice of rims.
The hub, what are the potential problems one could face compared to a normal hub?
You could go Sram new Force levers and RD or RED RD.
Bikes:
Open *UP* (2016.04.14)
AJS914
by AJS914 on Sat Mar 04, 2023 5:23 pm
The biggest problem with this hub is the $1500 price tag. I just don't see how they get people to buy it costing so much. Ditching the front derailleur sounds cool untill you see the price tag.
maurice1
by maurice1 on Sat Mar 04, 2023 10:33 pm
2 questions:
Can you configure the multiplier yourself for the smaller ring?
And since the common argument against 1x is the loss of power with angled chainline, we've all seen the graph a million times, has somebody tested if the aero/weight(?)/bigger chainring benefits outweigh the chainline inefficiency on the extremes of the cassette?
