OSPW For Shimano 12sp
wheelbuilder
by wheelbuilder
znerken wrote:One thing people don't seem to mention often with CS OSPW is that the open bearings require regular maintenance. I have over a couple of months tested both the original and the new Alpha RS with closed bearings. Yes, they look good, but even after just one ride on dry perfect tarmac and the bearings become scratchy. If you are a perfectionist like me who often take off the chain to rewax, it becomes quite sad to spin the OSPW cogs. I don't know about you, but taking them apart all the time to flush the bearings seems dumb. I guess you can just ignore it, but I can't seem to remember this being an issue with stock dura ace cages? The reason it happens on OSPW bearings is because tiny sand particles get inside. Here is a good video illustrating it: https://www.reddit.com/r/bikewrench/com ... Le74CEoNvF
After one ride there is a certain degree of this
This can not be overstated. As an ex mechanic who knows better, when building my current Diamante I was in a position to buy "halo" type products just to do so. I have the coated race version of the CS BB, and while they spin a long time unloaded, and the cranks do that Instagram "sticky freehub" frewheeling thing that is so popular, the seals need to be removed, flushed, and regreased with pricy thin grease in my experience....
EVERY 3 THOUSAND miles in dry conditions to maintain that performance. I now have a zip lock bag full of seals anticipating what the maintenance requirements are going to be.
alanyu
by alanyu
FlatlandClimber wrote:
Mon May 09, 2022 2:47 pm
Yoln wrote:
Mon May 09, 2022 12:41 pm
That's where I don't agree with you guys. I'm also obsessed with speed, hot-wax my chain, keep my drivetrain sparkling clean, sometimes rides corsa-speed on regular rides just for the love if it's marginal gains, put way too expensive grease on all my bearings, etc...
But after reading about Ineos choice to ditch OSPW, most of the triathletes doing the same on any recent built, and reading recent studies about OSPW, the consensus is that they provide a friction watts gain within the margin of error. And a aero watts loss, not within the margin of error.
So feel free to put them on if it's a piece of jewelry for you, that's all good. But don't come here and convince people that they'll make their bike faster. It's a marketing lie. Net net, taking into account aero drag, they'll make your bike slower.
Friction facts (no owned by Cermaic speed, so potentially biased now), ZFC and Josh Portner (Silca) have addressed independently of each other, that a good OSPW yields a single digits wattage improvement at 250W (usually quoted as 2-4 Watts).
This is non-sense. The drive chain loss with a DA chain treated with UFO v1 and stocked DA9000 system is ~3.1 Watts @ 250 Watts, including BB, chain and RD. Tested as motor driving 250 Watts and measuring power at hub. You try to believe an OSPW will reduce it to 0.X Watts, literally only BB friction?
FlatlandClimber
by FlatlandClimber
I have quoted the 3 best sources I know of. That's about as much as I can do.
I'd argue your numbers are off. I am pretty sure Adam Keiran quoted 2.5W for the chain alone and just under 98% total drivetrain efficiency.
But I am not really interested looking it up for an argument about literally half a watt 😂
Cervelo P5 Disc (2021) 9.1kg
S-Works SL8 (2023) 6.3kg
Tiforlife
by Tiforlife
Mon Jun 10, 2024 4:11 pm
https://velo.outsideonline.com/road/roa ... el-system/
"Poertner agrees that CeramicSpeed’s claims for an OSPW saving 2-4W are overstated and that the figure is indeed closer to 1-2W."
"According to Jason Smith of Ceramic Speed, formerly Friction Facts. The quoted 20W, or 8% loss is based on a new Shimano Ultegra drivetrain and wheels using stock chain grease, brand new bearing seals/grease and Ultegra hubs"
So in other words a stock drivetrain is 92% efficient, not 98%.
I own a Coated OSPW because I got it on closeout from the distributor and I fancied a bit of bike jewelry - to me the biggest negative is the extra noise.
alanyu
by alanyu
You are saying my numbers, which is presented by CS, is off? ~3.1 W is the number shown by CS when they released UFO v1. :noidea:
BenCousins
by BenCousins
Fri Apr 29, 2022 6:57 pm
The CeramicSpeed ones work perfectly. There is some gain to be had from lower friction bearings, low chain articulation and potentially lower chain tension.
However, they need more maintenance, a little tougher to set up and don't fit every bike bag.
But I love the looks.
How do you bend your neck to see it while riding?
FlatlandClimber
by FlatlandClimber
BenCousins wrote:
Mon Jun 10, 2024 9:47 pm
The hair cut I have is one I like the look of, despite me not being able to see it for most of the day...
BenCousins
by BenCousins
Tue Jun 11, 2024 9:36 am
I think the OSPW is not equivalent to hair cut. More like the length of your shoelaces.
Jaisen
by Jaisen
BenCousins wrote:
Tue Jun 11, 2024 10:44 am
Why are you arguing? They said they like the look, end of story. Would you argue if they told you they liked vanilla ice cream?
Tifosiphil
by Tifosiphil
I did find that very frustrating when I used to wear Giro Empires :oops:
BenCousins
by BenCousins
Jaisen wrote:
Tue Jun 11, 2024 1:27 pm
Again, that's not a good comparison. Buying an OSPW for looks is like buying a specific brand of vanilla ice cream based on the logo on the container.
cyclespeed
by cyclespeed
I was never convinced by OSPW cages and never bought one.
They are heavier, use more chain, and have more aero drag. And I personally think they look a bit stupid.
What does make slightly more sense to me is just changing the stock pulley wheels for something a bit nicer, lighter, spinnier.
Extralite make a 12 tooth hybrid ball bearing jockey wheel that is lighter, spins well and is 1 tooth bigger than stock. This is the route I have gone down, for far less cost than an OSPW like CS.
ultimobici1
by ultimobici1
Just bear in mind that having an OSPW fitted may look good, to you. But it voids any warranty you may need on that expensive mech. All for 3w?!?
cyclespeed
by cyclespeed
This paper;
https://core.ac.uk/download/pdf/29823669.pdf
is very interesting. Lots of in depth testing by a top level engineer. Lengthy reading but lots of useful nuggets in it.
milanv
by milanv
Nice discussion, guys.
Let's make sense to the thread name...
