Trek Domane 2023
Mr.Gib
by Mr.Gib
BenSiskri wrote:
Thu Apr 13, 2023 4:27 pm
I'm always surprised we don't see more GRX rear mechs used in CX; and it would seem a 'no-brainer' to use in a race like PR.....
Or at least that Ultegra rd that has a clutch. And maybe not just for Paris Roubaix, so many dropped chains throughout the classics.
LanceLegstrong
by LanceLegstrong
Mr.Gib wrote:
Thu Apr 13, 2023 10:25 pm
I run the Ultegra RX derailleur on my CX/gravel bike and it's been great. 1x for CX, 2x for gravel and never drops a chain.
Specialized Tarmac SL7
Specialized Crux
Velobuild 168
Trek Checkpoint ALR
hannawald
by hannawald
Not sure it has been discussed here before - this is the Tour Magazin test of the Domane SLR.
https://www.tour-magazin.de/rennraeder/ ... ane-slr-7/
Frame weight is quite nice below 1100g. Despite massively looking tube shapes BB stiffness very low. Overall they say it is not noticeably more lively then previous geneation. Other aspects seems quite good. How do you rate the climbing capability of the Domane? Any endurance bike better in this regard?
cpac54
by cpac54
Does anyone have actual frame/fork weights for the Domane SLR version (size 54 ideally, but any size would do just to have a reference).
hannawald
by hannawald
cpac54 wrote:
Tue Jun 20, 2023 4:08 pm
You will find the numbers in this article, not bad:
RDY
by RDY
hannawald wrote:
Mon May 29, 2023 4:08 pm
It's a threaded alu insert bonded into a carbon frame. It's never going to be as stiff as a properly toleranced, stiff press fit frame. One of the many reasons why they're a shit idea. Unfortunately the industry has decided they're to be the new snake oil.
g32ecs
by g32ecs
Proud owner of the previous version but using mine as a Gravel bike. Current set up is around 18.5lbs max at a size 50. The Isospeed does help a ton on gravel and thankful I have it
Nice to see there's some interest here
Cannoli
by Cannoli
The Domane makes an excellent gravel bike. Add a RedShift stem and some 38mm tires, and its super plush on the bumpy stuff.
Canyon Aeroad CFR Di2 | Canyon Ultimate SLX 9.0 Di2 | Trek Domane SL5 Disc (Gravel Bike / Fly-Away Road Bike) | Orbea Tera H-30 Disc (Touring Bike)
sigma
by sigma
TobinHatesYou wrote:
Mon Feb 20, 2023 4:26 am
sigma wrote:
Mon Feb 20, 2023 4:23 am
Mon Feb 20, 2023 4:18 am
Build done.
Looks terrific. Which wheels and bar did you go with? Saw one in person recently and the paint job alone almost got me.
Light Bicycle WR50 wheels and 38cm Coefficient RR bars.
How are you feeling about those coefficient bars after this time? I am considering getting a pair to test out,,,
Lots of bikes: currently riding Enve Melee, Krypton Pro, S Works Crux, S Works Epic Evo, SL7.
In build: SW SL8
TobinHatesYou
by TobinHatesYou
sigma wrote:
Thu Aug 03, 2023 1:32 pm
Even after switching to a 150mm stem, the aero computer mount position is a bit cramped. I also wish the hoods were a bit narrower. I have been eyeing the Aerocoach Ornix as an alternative.
wheelsONfire
by wheelsONfire
AXS to, just less friction....
Bikes:
Open *UP* (2016.04.14)
sigma
by sigma
Thu Aug 03, 2023 6:38 pm
I am playing a lot with the stem versus narrower bars (and my subsequent hip angles). It's a lot more tricky than I thought it would be to dial it in. I like the Ornix from handling one but never ridden it. Pretty stiff piece of kit.
In build: SW SL8
RDY
by RDY
Anyone found an off the shelf solution for the Domane running a third party stem and bar combo with cables going into the headset, which isn't the standard Trek part? Trek standard part uses standard round spacers if you need them, so has a cable run from the bar to headset cover, past the round spacers, which is less than ideal. AFAIK usual FSA / Deda / Ritchey solutions don't work because they use standard IS52 bearings and Trek uses some god-forsaken IS51 standard ... though maybe their spacers / covers will fit on top of the Trek bearing?
Also, anyone know of a third party 2 bolt seatpost being done yet? Darimo said no, and the 1 bolt Trek design isn't great.
TobinHatesYou
by TobinHatesYou
RDY wrote:
Wed Feb 07, 2024 1:58 pm
The FSA ACR split ring mates with the Trek 51mm bearing, but it’s much too tall.
RDY
by RDY
Wed Feb 07, 2024 2:35 pm
I assume you mean it's in danger of being unstable due to the profiling of the frame, as height per se is irrelevant if you're adding spacers? The Ritchey one is much lower profile and generally more stable than the ACR part in my experience. If the ACR part fits the 51mm bearing, so should the Ritchey one.
