Trek Domane 2023
Yeah. The difference is huge in every way. Not even in the same category. The stack is so low on the RSL. And the trail is much lower. Interesting that Trek doesn't provide front center. I bet it's around 575mm. But since you're running short cranks you won't have toe-overlap issues.
Did you settle on 155mm cranks after the short crank experimentation?
pdlpsher1 wrote: ↑Fri Dec 23, 2022 3:25 amYeah. The difference is huge in every way. Not even in the same category. The stack is so low on the RSL. And the trail is much lower. Interesting that Trek doesn't provide front center. I bet it's around 575mm. But since you're running short cranks you won't have toe-overlap issues.
Yeah my preference is for 155mm at this point, but I'm also good with 165mm. All the 155mm options are unfortunately pretty heavy. Toe overlap really isn't an issue other than the fact that I'll mess up my shoes while soft-pedaling around a parking lot.
So you'll have it built and tested before Snelling?TobinHatesYou wrote: ↑Thu Dec 22, 2022 7:53 am
It’s mostly that. The new Madone’s barstem is too short and too high, so I’d have to use a standard stem with it or get something like an EXS Aerover or Farsports F1.
Plus it has a 998mm wheelbase, low trail, T47 BB and should arrive in 2-3 weeks.
Congrats on the purchase, looks cool!
Yeah, I would be really interested in one but the price has been holding me back so far.wheelsONfire wrote: ↑Thu Dec 22, 2022 1:42 pmJesus, that is one expensive framesetTobinHatesYou wrote: ↑Thu Dec 22, 2022 7:58 ampdlpsher1 wrote: ↑Thu Dec 22, 2022 7:17 amYeah. I'm interested in knowing what attributes you liked as a racing bike. To me personally three things that I liked about are 1) low BB height, 2) internal downtube storage, and 3) slack geometry. Comfort is also nice but I dislike proprietary seatposts. I've found that a light and round seatpost such as the Darimo provided just the right amount of comfort without any downsides.
The RSL does not have the DT compartment, has a beefed up BB shell and I swear it looks like DT has a deeper aspect ratio. The regular Domane has some chainring size limitations as well. Apparently it can only take up to a 33t inner ring with SRAM, but a 36t inner ring with Shimano. The RSL can take up to 40t inner rings because it has a narrower rear triangle (35mm max tire clearance instead of 38mm)
Very interested to hear your ride impressions and follow the build. The RSL geometry also fits me a little better and I was a huge fan of the rim brake domane in both the first and second (with isospeed on the front) versions as it was still light and fun to ride. I passed on the disc iterations because they felt almost too plush and non-responsive, but this looks pretty great and would be excellent for a midwest poor roads endurance bike.TobinHatesYou wrote: ↑Fri Dec 23, 2022 4:42 am
Bike should be ready for Cantua unless the shipping date is a lie. Whether the body will be ready is another story.
Lots of bikes: currently riding Enve Melee, Krypton Pro, S Works Crux, S Works Epic Evo, SL7.
In build: SW SL8
In build: SW SL8
I think you're right on the DT aspect ratio
https://cyclingtips.com/2022/04/new-tre ... ix-femmes/
Looks like use half the Madone mold and half the Domane.
jfranci3 wrote: ↑Sat Dec 24, 2022 9:47 pmI think you're right on the DT aspect ratio
Like, I’m not crazy right? The Domane RSL is going to be faster in real-world riding than a Madone if you can lower your shoulders even 1cm.
nice !
let is know frame/fork right.
2024 BMC TeamMachine R
2018 BMC TImeMachine Road
2002 Moots Compact-SL
2023 Pivot E-Vault
2023 Pivot E-Vault
TobinHatesYou wrote: ↑Sat Dec 24, 2022 11:18 pmjfranci3 wrote: ↑Sat Dec 24, 2022 9:47 pmI think you're right on the DT aspect ratio
Probably a tossup. It might depend on how low the bottle cage sits on the Domane and how the new Madone rides. The Madone has a pretty low cage mount (where the tube is wider) and better seat tube 'sail' in crosswinds. They tune the Domane to ride fairly firm by current standards, so the Madone won't be radically better if it's decent. They both take pretty wide tires. The Domane is 10mm longer front and rear, so it loses a touch of draft-ability, but will ride better just because of that.
But what if the guy on the Madone bends his elbows one addition degree?TobinHatesYou wrote: ↑Sat Dec 24, 2022 11:18 pmLike, I’m not crazy right? The Domane RSL is going to be faster in real-world riding than a Madone if you can lower your shoulders even 1cm.
Kidding of course. I live by the phylosophy that you never need a practical reason to buy a new bike. That RSL will look fantastic, ride great, and like any nice new bike give added motivation to get out there and train - a big win in my book whether it's faster/fits better, or not. Looking forward to your ride impressions in comparison with the Madone.
It's 200gr for a better riding Emonda SLR H1 for most people. I don't think it gets the 8w-ish credit of the Madone on a test, but it's not a bad idea for an aero backroad bike that doesn't look like it's trying too hard. If it took 38 or 40s in real life, it would be the the perfect smooth gravel bike and is probably the best BWR bike.
I'd still like to replace my 2018 Checkpoint with a +1 dove 2021 Domane classics bike.
What's the situation with third party stems or cockpits on the new Domane SL / SLR? Does it come with a headset cover / spacers that will work with them, per the Gen6 Madone SL? If not, what's the upper headset bearing standard and size?
Edit, had written Madone SL / SLR, meant Domane SL / SLR
P.S. Trek only have the lower IS51/40 bearing listed on their service guide. Not the upper.
The Domane has IS51/40 upper and lower bearings to accommodate its round 1-1/8" steerer + internal cable routing. There is a headset bearing cover for regular stems + spacers.RDY wrote: ↑Sun Jan 01, 2023 1:07 pmWhat's the situation with third party stems or cockpits on the new Domane SL / SLR? Does it come with a headset cover / spacers that will work with them, per the Gen6 Madone SL? If not, what's the upper headset bearing standard and size?
Thanks. Does that come with it, or is it a separate purchase? If not, part number?TobinHatesYou wrote: ↑Sun Jan 01, 2023 11:24 pmThe Domane has IS51/40 upper and lower bearings to accommodate its round 1-1/8" steerer + internal cable routing. There is a headset bearing cover for regular stems + spacers.RDY wrote: ↑Sun Jan 01, 2023 1:07 pmWhat's the situation with third party stems or cockpits on the new Domane SL / SLR? Does it come with a headset cover / spacers that will work with them, per the Gen6 Madone SL? If not, what's the upper headset bearing standard and size?
