Fastest Tubular tire 2022
sindrestokk
by sindrestokk
I am looking for a new set of tubular tires and i am looking for some guidance. want a fast rolling lightweight tire price does not matter around 25mm.
calleking
by calleking
2023 Wilier Rave SLR
2022 Wilier Filante SLR
2021 Cannondale Scalpel Carbon 2
Singular
by Singular
If you're not willing to step into track-tubs territory, Corsa Speed it is.
LouisN
by LouisN
Or Dedicated TT tubs like Veloflex Record.
Corsa Speed is 23 mm ;).
It's not up to date.
Would like to see how Veloflex Pro Tour Race scores in that test.
Louis :)
mrlobber
by mrlobber
Veloflex "on paper" should be +/- on the same level as Conti ProLtd (I think we even had some discussion around here with indirect conclusions from BRR testing), albeit from my own riding with both of these I suspect the Conti is in fact slower despite all their "Blackchilli" blah blah compound.
The new Michelin Pro Competition Cup tub might be interesting.
xav
by xav
mrlobber wrote:
Fri Mar 11, 2022 11:44 am
We've got a Michelin Power Cup tubular on order for testing, should be a couple of weeks. The tubular VF Record is slower than the tubular Corsa Speed which is currently the fastest tubular
sindrestokk
by sindrestokk
xav wrote:
Fri Mar 11, 2022 3:20 pm
How are the corsa speeds on puncture protections? going to use them for races only might ride gravel and cobbles.
DHG01
by DHG01
sindrestokk wrote:
Fri Mar 11, 2022 5:35 pm
My rear, in 25 mm, punctured within 100 km; I wasn't able to repair (though I think I wasn't using the right sealant).
The front one completed its lifecycle though; I now use it as spair.
I think they are too fragile for cobbles.
I usually ride 25 mm; I have recently tried Zipp Tangente SL. They are 27 mm; with no scientific data, I found them very fast. I don't recall my Corsa Speed, but they do seem faster than normal Corsa (I rode both one day after the other).
Being tubular, they width will be very close to the 27 mm announced; not too different to 25 mm.
Puncture protection is supposed to be weak; but being latex and 27 mm, sealing isn't an issue (already punctured and fixed....).
Dirt cheap now at Merlin; might be another option.
DHG01
by DHG01
Off topic - are typical tubeless really as fast as, eg Corsas? I ve seen BRR data; but I think I read the smaller drum penalized softer casing tyres like Corsas.
Yoln
by Yoln
Nice! Are you also going to test clincher and tubeless versions?
#RETIRED# Lynskey “the Do-it-all Helix” 🧬:https://tinyurl.com/bdmb5y24
Scott2017
by Scott2017
How did that Michelin Power Cup tubular fare in testing?
C36
by C36
Also interested in the result. Understood you recently had the different VF under test ?
Aress
by Aress
Cycles et form from france tested them to be equaly fast to the clincher version
Kayrehn
by Kayrehn
LouisN wrote:Or Dedicated TT tubs like Veloflex Record.
Louis :)
Corsa speed is available in 25mm
Sent from my Pixel 6 using Tapatalk
Scott2017
by Scott2017
Aress wrote:
Sat Apr 01, 2023 3:27 pm
Could you share the link to their test? Checked their website but couldn't find anything about the Power Cup tubular version.
