33g Inner Tube - Ridenow TPU
Forum rules
macwatt
by macwatt
Scania123 wrote:
Tue May 16, 2023 9:52 am
I ordered some Ridenow 85 mm tubes but recieved 65 mm. Does anyone have experience from what's the deepest rim depth that works with 65 mm valve lengths? I got the tubes cheap so can't be bothered to send them back.
I've used 65 mm with Roval Rapide CLX wheels rear is 60mm deep it was ok and usable but certainly not much valve stem visible.
MilesG813
by MilesG813
I use the 65mm on my PCW 6560s which are 60mm at the valve. Just enough for the chuck to grab.
2022 Specialized S-Works SL7 I Ultegra R8170 I Princeton Carbonworks 6560
2012 Cannondale CAAD 10 I 105 R5700 I Zipp 404s
jlok
by jlok
Used 65mm valve on my WR65, just right to allow the use of screw on pump chuck.
Turrifik
by Turrifik
Are you using a thread-on or clamp-on Chuck?
jlok
by jlok
Steve Curtis
Location: Hampshire UK, Dublin Ireland and Geneva Switzerland.
by Steve Curtis
Just an fyi. After some testing and purposefully puncturing a tube multiple times, the Park Tool self adhesive patch's work brilliantly on these tubes.
I tried a the lezyne patches which were ok and the wiggle lifeline ones were ok too, but park was a clear improvement.
Keykey1985
by Keykey1985
Steve Curtis wrote:
Wed May 17, 2023 7:51 am
Schwalbe patches work well on Aerothan tubes, I had one hold for over a year with ~5000 at miles, presume they would work as well with any other TPU tube?
Steve Curtis
by Steve Curtis
Keykey1985 wrote:
Wed May 17, 2023 8:24 am
I tried the schwalbe too, but they weren't as stretchy vs the park ones.
The tubes stretch to fit the tyre and remain stretched, the park patched allow for this it If you have a tube that's already stretched then the schwalbe are fine. ( or don't intend to use the tube in a larger tyre later )
usr
by usr
Thanks, in particular because the Schwalbe patches seem to be out of stock more often than not.
Stretch will be an important factor, even on a pre-stretched base. There's still *some* elasticity left or else you wouldn't reuse even in the same tire.
Steve Curtis
by Steve Curtis
usr wrote:
Wed May 17, 2023 10:45 am
I picked up the schwalbe patches to use as frame protectors 🤓 they're great for that.
charirider
by charirider
Hey fellow weightweenies
As many people in this topic mentioned, TPU tubes have different sound to them when rolling +30kmph.
What exactly the difference is comparing to light butyl/mix tubes?
Now I am riding Panaracer R'Air tubes, Gillar tyres mounted on Vision Metron 40sl carbon clinchers.
Will switching to TPU, let's say RideOn, five me more "hollow" carbon cool rolling sound?
2018 Cannondale SuperSix EVO 2 rim size 56 (raw stripped) 6.9kg
2014 Bridgestone Anchor CX6 Equipe size 55 (cyclocross) 9.8kg
andy4g63
by andy4g63
Couple of questions, regarding size:
I had a gravel ride on Sunday and my friend had a tube with a very short valve...
So I tried and we used the Ride now TPU tubes that I carried as a spare...
Regular 36 g version.
First one started showing leakage after 15 min...
We stopped and put the second one in.
I did clean the tire , but not the rim....
After another 20 min the second one started leaking.
At this point I realized I had a valve extension so we could use my friend regular tube and we got back...
The first TPU tube I threw away.
The second one took home to investigate...
Appeared that the tube had not one , but 2 small holes sort of facing the rim side...
No leaks at valve or where the tube is glued...
Do you guys think they are viable option for gravel tires_40mm???
I know on the box it says 32...
The only problem I see is where the tube is glued/joined...
This area was very visible during inflation... You can actually feel and see a little slope there, which sort of disappeared when inflated more...
Upon further investigation I came to conclusion that is still doable as spare as long as you clean good rim and tire before installing...
LMK what you guys think.
Cheers 🍻
Aesch
by Aesch
If I understand correctly you've undersized significantly making the tube thinner and more vulnerable. If you choose the right size you should be fine.
jayjay
by jayjay
andy4g63 wrote:
Wed May 31, 2023 1:31 pm
No.
maurice1
by maurice1
They make gravel tubes. I'm not sure what you expected using road tubes in a gravel tire
