Pro Vibe Evo (Shimano integrated cockpit)
kode54
by kode54
On the bottom where the tape is...is that a channel for hydro hoses? Appears that this could be used on a Caledonia 5?
- Factor Ostro VAM Disc
- Factor LS Disc
- Specialized Aethos Disc
- Sturdy Ti Allroad Disc
- Guru Praemio R Disc
FactoryMatt
by FactoryMatt
kode54 wrote:
Sun Mar 12, 2023 4:51 pm
Yes they allow for a couple different routing methods.
kode54
by kode54
Interesting. Must be able to save some weight from the C5 heavy stem and handlebar combo...even though its heavier than other integrated combos.
- Factor LS Disc
Nezz0r
by Nezz0r
In the side view the drops look really like rubber bananas :lol:
Picture credit: @matosvelo via Twitter (Matos Vélo)
But it looks really okay on that bike :thumbup:
Eterna7m
by Eterna7m
Lmao rubber banana
mrbrown4001
by mrbrown4001
FactoryMatt wrote:it's a size 40 x 105
That’s unfortunate. All these brands are so ridiculous with their “aero” handlebars
FactoryMatt
by FactoryMatt
so i saw a pic of this bar with a K-Edge mount, and thought it'd be a direct bolt-on. not so. the bolt spacing is only like 17.5mm. I had to basically drill/extend a hole between the front three on the mount and the back slot. ended up hacking it up pretty good....
also the stack on this bar is SUPER low. had to add another 15mm of spacers to retain the fit i had.
FactoryMatt
by FactoryMatt
Chuffed on these bars so far. If you wrap the top it can be pretty bulky for better or worse tho.
FactoryMatt
by FactoryMatt
TIL OE bolts are trash. galled out after two cycles. 5.4nm torque. used copper anti-seize. trash. the boss the thread into was untouched and took a tap no problem. replace these bolts asap. why o why is PRO stuff sub par compared to Shimano? because it's dutch specced?
MatosVelo
by MatosVelo
I read that some of you are interested about this cockpit, you can find my review here : https://www.matosvelo.fr/index.php?post ... s-a-revoir
Pads are not perfect.
Scania123
by Scania123
MatosVelo wrote:
Tue Jun 13, 2023 7:22 am
Very good review, thanks for posting!
MatosVelo
by MatosVelo
For me, it's really an excellent cockpit, very ergonomic. Unfortunately the pads aren't perfect and tend to peel off on the top bend.
The original versions of pads was really bad.
Second version are better but not perfect.
I've glued this on with tubular glue for the moment.
CustomMetal
by CustomMetal
Do you have an English translation?
Allegra- Steel Lugs TBC
Aurelia- Stainless All Road 8.5kg
Bertha- TT 9.8kg
Perdita- Ti Turbo bike 8kg
Serenity- Ti Gravel 9.5kg/8.9kg
Verity- Ti Aero 8.2kg
Alya- Ti Climbing TBC
MatosVelo
by MatosVelo
No, but you can have an approximate translation with Google : https://www-matosvelo-fr.translate.goog ... r_pto=wapp
calleking
by calleking
Google translate worked fine for me. I'm interested in these handlebars as I'm looking to replace my stock Filante handlebar that is a wooping 43cm!
2023 Wilier Rave SLR
2022 Wilier Filante SLR
2021 Cannondale Scalpel Carbon 2
